boostedgp
Post by boostedgp »
Lowered on H&R springs and shackle kit. Stil. On Oem shocks for the moment.
225/45/18 wheels and tyres. Image
caddychris2002
Post by caddychris2002 »
Busy few days. Fitted new leather armrest and centre console, fitted some led lighting that does sequential indicators and a few other things. replaced strut tops that where clunking. Replaced rocker cover seals and gave the old girl an service.
Trouble i have now can't get injector 3 to seal properly. Doing my f-ing head in. Any pointers anyoneImageImage
www.dav-tec.co.uk
www.facebook.com/davteceng
Autowatch Ghost Installer
Mods:
thecolourpurple
Post by thecolourpurple »
@caddychris2002 . Maybe need new stretch bolt?
caddychris2002
Hi @thecolourpurple I should of said i replaced all the bolts, seals and copper washers etc.
Ordering more new bolts and copper washers from tps tomorrow going to remove the injectors for 3 and 4 make sure the seats are super clean and try again
www.dav-tec.co.uk
Mods:
Ripley55
Post by Ripley55 »
Just collected her from Paint
Custom Bumper Caddy/Touran R. It’s mint, well pleased Image
ViralEye
Post by ViralEye »
Started the rear seat conversion and it's taken most of yesterday and this morning to get the panel out Image
Test fitted the single seat to see how it would look tooImageImageImageImageImageImage
ViralEye
Post by ViralEye »
Oh, and I also did the rear door trick Image
Such an easy and chill mod to doImage
ljk
Post by ljk »
Rns510 dab, with 9w7 Bluetooth module.. Much improved over old rcd 300 🤣
Peng
Post by Peng »
VRS seats are in today. Sooooo comfy, so much betterImage
Fran1981
Post by Fran1981 »
Borrowed Vcds from a mate and did some coding needle staging, doors lock after 10mph, digital speedo, fogs as cornering lights, is there anything else I can do? It’s a 2018 maxi highline 150bhp
ViralEye
Post by ViralEye »
All today, I decided to drill into my fuel tank by accident
What's the best way to seal it up? Sikaflex? Epoxy?
Ah man, that sucks.
Sikaflex and a patch of something like flash band will do as a temporary fix but you're probably best replace it if you can.
ViralEye
Post by ViralEye »
I think I'm going to try and clean it best I can, then epoxy resin it and hope it holds. If it fails I can get to it easy enough to re-do it.
#Gutted ImageImage
davinci
Post by davinci »
@Peng seat are looking sweet
sheepy92
Post by sheepy92 »
Bit of DIY carpet lining with zero patience Image
