Dash Cam
Dash Cam
I want to put a dash cam into my Caddy(2014). I want to power it so that power is applied when I turn on the ignition. On my previous car (Golf MK4) I had it powered from the head unit which was an Android unit. In my CaddyI have a RNS315 which I intend on keeping, I would need to power a USB connection so are there any ways/kits to add switched usb. Or have you done it another way?
- Cabbs
Re: Dash Cam
[mention]edie209 [/mention]
Dependant on the make of your dash cam, there are hardwire kits available now. Mine is hardwired directly into the fuse box on the switched live rail. When I fire the van up on comes the cam. What make is the dash cam?
Re: Dash Cam
Hi, Thanks for the reply
My dashcam is a Xiaomi 70mai
- Cabbs
Dash Cam
Type in eBay.......... “70mai dash cam hardwire kit”. There’s loads for sale. You can wire it directly then to the switched live side of the fuse box. They come with 3m of cable and instructions manual.
Re: Dash Cam
I’ve got a nextbase camera and I’ve wired it directly to the ignition live in the fuse box using a hardwire kit. It’s not a difficult job to do, and it saves having wires trailing everywhere.
- Papa Bear
Re: Dash Cam
I bought a twin usb 12v hard wired thing, wired back to the fuse box and positioned on the shelf above the windscreen. Cam plugged into that so no trailing wires.
Black
Marmite lover!!!
VCDS
Black
Marmite lover!!!
VCDS
Re: Dash Cam
Thanks guys that is really helpful I will get that ordered up.
Is there any information available about the fuse box and what is available and switched.
Sent from my HD1900 using Tapatalk
Re: Dash Cam
There is information somewhere about what rail is permanent live and what rail is switched live. I can’t remember which is which sorry.
Re: Dash Cam
I suppose much of the information here is in the locked groups. Hopefully I will gain access soon.
But thanks for replying
Sent from my OnePlus 7T using Tapatalk
- Dons101
Re: Dash Cam
@edie209
you have enough posts just read ALL of the message in announcements and reply to it to request access.
2011 Caddy Maxi Navy Blue, MFK remap to 142.6 bhp
Restless, avid traveler. Would rather hike in the mountains, fish in the sea, canoe in a lake or river than surf a couch.
Re: Dash Cam
Ok I will do that thank you
- Cabbs
Re: Dash Cam
adding extra fuses / circuits permanant / ignition live
https://r.tapatalk.com/shareLink/topic? ... source=app
Re: Dash Cam
Thanks for the link, I can't access that part of the forum just but soon hopefully I have requested access.
- Marin97
Re: Dash Cam
My opinion on this is that its best for dash cam to be powered all the time, cuse if that dash cam has option to record on movement, or on for example car hits your front side on parking, your cam can save it for you to look it later..
For driving you can use old mobile phone and some app of play store
Poslano sa mog H4113 koristeći Tapatalk
