vw golf 7r steering on Caddy 2K.. Possible??
Hi all
Anyone try or have installed VW Golf 7 R steering on VW Caddy 2K?
Is it possible to work all 100%? This Caddy have Golf 5 full FIS cluster.
I appreciate any feedback or help possible
BR
BR
Re: vw golf 7r steering on Caddy 2K.. Possible??
Hi,
Yes it can and has been done, lots of forum members have this.
Your mk5 full FIS will make no difference, it is the same as Caddy/Touran in so far as steering wheel control requirements.
Great to know that's possible. The question is how
Anyone have any tutorial/help documents to start make this happen?
Thanks. BR
Thanks. BR
- Giddy
Oh yes, lots of info here, one you get access. Will keep you busy for quite a bit to read and process it all
Ohh no problem If is here, i will read and learn and maybe help in the future
As far as i know, this can only be done with steering wheels that have golf mk7 look, from vw polo 6C and scirocco 2016and up
Thanks for your input Michel I saw also some Xhorse module that can work with the wheel.
Link: http://xhorse.uk/product/mfsw-module-en/
Also MFDColor3D have other module that work, but i'm study the problem to put this mfsw working
- Ripley55
I used Polo wheel as I wanted to keep the buttons Red
Chestnut Brown Caddy MK4 Maxi Life 2.0Tdi 150bhp , 18â Matt Bronze OZ Ultraleggeraâs 8Jx18 ET45 on Bridgestone 225/40/18âs
Where do you buy these steering wheels?
There are many sources for mk7 steering wheels. New from VW and even some online auction sites. Used, again the online auction sites are a good source or you could look at breakers yards local to you or even online.
Thanks Doc,
Your alternatives are given though.
I was thinking more of webshops etc.
Cheers.
I tend to stay clear of websites selling genuine VW parts as they'll be buying the parts from VW who you can go direct to yourself and cut out the middle man.
Also interested in doing this, is it only the MK7 and up that it works with you can you go to earlier cars?
- Alex mc
Hi all sorry to jump in Iâm looking to do this on my Mk 4 caddy start line using the polo mfsw . After reading some posts / threads on the forum am I right saying this swap is more straightforward. Iâm guessing reading them most of the swaps have been retro fitted to mk3 etc with bit higher spec than mine. I found 1 for my 4 but it was higher spec than mine . I couldnât find one for my spec van . My question is will I still need module new stalks etc to do this? Which would I need if had to do it .I just donât want to get stung online buying wrong part etc . I unfortunately donât have VCDs to pull out info of whatâs there. I like doing things myself if and if it is straight forward enough to change over I would change the bits and pay someone to code it all in. any help would be greatly appreciated
I was wondering what are the necessary steps and or parts to make the make the cruise control work if i get my hands on 1 of these wheels?Michel R32 wrote: âMon Dec 14, 2020 12:28 pm As far as i know, this can only be done with steering wheels that have golf mk7 look, from vw polo 6C and scirocco 2016and up
Touran 1T3 2.0 TDI
