C Chis
Posts: 1698 Joined: Fri Mar 06, 2020 1:13 pm
Post
by C Chis » Fri Feb 05, 2021 10:29 am
Managed to salvage a stand-alone RLS mount, sensor and cover out of Golf, bargain at £10
Quick job as I already had a mirror mount one installed following the how to in the tech section
My VR6 Build Thread and Details can be Found
Here
sherwood
Posts: 27 Joined: Mon Feb 08, 2021 1:43 pm
Post
by sherwood » Sun Feb 14, 2021 8:52 am
C Chis wrote: ↑ Thu Jul 09, 2020 10:24 pm
A quick picture at dusk, I’ll take some better ones over the weekend after I’ve cleaned the carpets, covered in muck and straw at the moment
Hello and congratulations on the caddy.
Excellent work this, what model is the light?
Thank you.
sherwood
Post
by sherwood » Sun Feb 14, 2021 8:59 am
C Chis wrote: ↑ Sat Jan 09, 2021 3:47 pm
New rear lights fitted and coded in using the rather good how to guide in the “how to” section! Many thanks to Doc for writing it up and sharing
And error free LED number plate lights also fitted, straight fit, no mods!
Rear lights and LED’s all next day delivery from travelinlite
I would also like to do this job, great!
But unfortunately I am not yet allowed access to the whole forum.
C Chis
Post
by C Chis » Sun Feb 14, 2021 11:11 am
[mention]sherwood [/mention]
Thanks!
The light console came from a Passat, I went down the Passat route as I was struggling to find a salvaged W8 light for sensible money and I really wanted somewhere to store my sunglasses, saves them getting crushed, bent, scratched in the glove box.
You have enough posts now to request additional forum access to the technical sections, get your request in and you should be upgraded within about a week.
It’s well worth the wait!
Here
dawelec
Posts: 8 Joined: Wed Jan 29, 2020 10:52 am
Post
by dawelec » Sun Feb 14, 2021 6:20 pm
Rear lights look great
, I wasn’t aware they needed coding in but I guess I will find out when I have full access
C Chis
Post
by C Chis » Sun Feb 14, 2021 6:25 pm
Buddy, preface lift van’s are easy to do with VCDS, other ones will require VCP to edit the BCM to achieve the same effect
Worth doing properly as it’s gets rid of the lamp error on the dash and lights up the bottom bar, I’m loving them!
Here
dawelec
Post
by dawelec » Sun Feb 14, 2021 6:31 pm
Thanks man, mine is a 2013 Caddy Maxi so would I need VCD?
Also is travelinlite a member?
C Chis
Post
by C Chis » Sun Feb 14, 2021 6:33 pm
No worries!
Yeah, I think you’ll need the BCM coding tweaked to get the bottom bar to light up as a sidelight.
Would be worth posting up to see if there’s anyone local to you that can make the changes
Not seen travelinlite on here.
Here
dawelec
Post
by dawelec » Sun Feb 14, 2021 6:37 pm
Thanks, I will do, So I guess it’s a company then that you’ve got your lights and LED’s from?
C Chis
Post
by C Chis » Sun Feb 14, 2021 6:41 pm
Yeah, they seem a good company, genuine parts, not to pricey (my local TPS don’t deal with the public and VW commercial won’t post) and next day delivery.
Here
dallin86
Posts: 8 Joined: Sat Feb 27, 2021 7:56 am
Post
by dallin86 » Sun Feb 28, 2021 7:00 am
awsome build mate
C Chis
Post
by C Chis » Sun Feb 28, 2021 10:31 am
Cheers buddy, doing my best to make it a comfortable van for mountain biking
Here
C Chis
Post
by C Chis » Thu Mar 04, 2021 12:34 pm
So, after a wait of almost 11 weeks while my rear bumper has been travelling back and forwards to the paint shop to have a couple of paint faults fixed post colour coding I’ve finally got the bumper protector fitted!
Good coverage and should reduce my chances of scratching the flat section of the bumper when moving bikes, etc in and out!
Finishes off the look I was aiming for at the rear too.
Here
Posts: 5163 Joined: Sat Feb 18, 2017 10:52 pm
Post
by the swan fiend » Thu Mar 04, 2021 12:53 pm
This build just keeps getting better and better mate. The exhaust looks great, as does the bumper......it was worth the wait!
C Chis
Post
by C Chis » Thu Mar 04, 2021 2:28 pm
Cheers buddy!
Only problem with bolting new shiny stuff on is that it starts to show up the other small bits that need attention like the small dents and dings!
I’m dreading the day I wake up and add a full respray to my mods list!
C Chis on Thu Mar 04, 2021 2:28 pm, edited 1 time in total.
Here
