Bi xenon coding help
wildybeast
Post by wildybeast »
fitted the bi xenons but having trouble coding with obd eleven.Is there anyone that can code these for me. 2019 caddy life Ime in Lincoln but can travel a reasonable distance. Thanks
Sabbunsingh
Re: Bi xenon coding help
Post by Sabbunsingh »
You need find someone with vcds(vag com) and follow the "how to" in this forum. It has all the info you need
When does this ever stop!!
Did mine with OBDEleven using the VCDS coding from the How to.
wildybeast
All working now.I got the part numbers and codes all from the How to thread but missed one of the codes.What a great forum Thanks to all .Ime skint. :D
nik_740
Post by nik_740 »
I also have the Bi-Xenon’s in my car but the DRL doesn’t work. This is also coding problem I think? I hope I can get a upgrade so i can see the How-To page
Apply for access, you have the post count ...
wildybeast
petrev .are your drls on when light switch is on auto in the daylight.? Mine arnt and think they should be .
nik_740
Post by nik_740 »
@petrev
I have applied the day before yesterday. So I am hoping I will be upgraded before or in begin of this weekend so I can fix my DRL issue and take some photos to show also here on the Forum
wildybeast wrote: Fri Mar 26, 2021 4:10 pm petrev .are your drls on when light switch is on auto in the daylight.? Mine arnt and think they should be .
I'll have to check ...
wildybeast
Sorted Thank you.
Cool
What did you have to set/change ?
wildybeast
Drls as position lights (much brighter ) if i remember..made lots of changes such as fog as comming home and leaving.drl off on indication.fogs as turning lights.
Servicon
Post by Servicon »
Hi guys, my fogs are on with the led drl's but off with headlights. How do I deactivate the fogs on vcds to only work with switch pull? How do I activate auto lights? Any help would be much appreciated
fetue
Post by fetue »
Hello, I’m William from Portugal and I also have the Bi-Xenon’s in my vaddy but the DRL doesn’t work. This is also coding problem? I cant see the How-To page :( just registered here
J.clarke
Post by J.clarke »
petrev wrote: Fri Mar 26, 2021 12:47 pm Apply for access, you have the post count ...
How do I apply for access please
