NZ 1.2TSi Build
Labern
Re: NZ 1.2TSi Build
Post by Labern » Fri Apr 09, 2021 1:57 am
My cheap 2nd hand wheels came off a Audi and it had some RS center caps so I replaced them with some Blue VW ones. Just a small touch ImageImage
Sent from my SM-A505GN using Tapatalk
Labern
Re: NZ 1.2TSi Build
Post by Labern » Fri Apr 09, 2021 2:07 am
Just installed cruise control. Easy job. Only had to program engine for some reasons.
Not to get a MFSW. Not sure what to get yet. I want to keep my airbag I think but a flat bottom would be nice. Would also like to change to highline gauges. Image
Labern
Re: NZ 1.2TSi Build
Post by Labern » Wed Apr 14, 2021 10:04 am
Just installed the center dash box with lid. Looks so much better then the open tray.
Also got the blue rings for the air vents which I am also really happy with. Image
Labern
Re: NZ 1.2TSi Build
Post by Labern » Sat Apr 24, 2021 11:04 am
I have been in touch with darkside developments about my ride heights for the front springs. They really pulled through and sent me some slightly lower one's. Very happy with their service even though im in NZ. Whilst installing them I took the time to paint my rusty rotors black and calipers red. Not sure if I like the red now. Maybe black would have been a better option. Image
Labern
Re: NZ 1.2TSi Build
Post by Labern » Tue Apr 27, 2021 12:56 pm
3D printed a reverse camera holder today and have plastic welded it into the number plate light cover.ImageImageImageImage
Labern
Re: NZ 1.2TSi Build
Post by Labern » Mon May 10, 2021 12:27 am
Did a bit more work on the van this weekend.
Changed the rear badge to black one, change sided blinkers to blacked out ones, rear wiper delete and covered the front headlining.ImageImageImage
Labern
Re: NZ 1.2TSi Build
Post by Labern » Tue May 11, 2021 11:47 pm
Change my pedals today. Makes a nice difference to the look.Image
Labern
Re: NZ 1.2TSi Build
Post by Labern » Tue May 11, 2021 11:52 pm
Have run an extra wire for the cabin light backlight and also some extras for the rain sensor that I have on order which should be here anytime soon. I also run a microphone for the head unit that clips into the cabin light. There is also 4G aerials for the head unit that I have put just above the windscreen. Now I'm cable wrapping them all together and 3D printed some clips to retain it to the frame in the holes that are already there. ImageImage
Labern
Re: NZ 1.2TSi Build
Post by Labern » Sun May 16, 2021 12:25 am
Got all my wiring done and headlining in. I started insulating with dacron but used up what I had pretty quick. It was going to end up expensive so changed over to fibreglass insulation. Way cheaper and was able to do the whole van.ImageImage
D14_KYE
Re: NZ 1.2TSi Build
Post by D14_KYE » Sun May 16, 2021 7:01 pm
That headline looks so good
Reason: Quote removed
