Vanborghini ex BG maxi
sih_27
Re: Vanborghini ex BG maxi
Post by sih_27 »
I was up there too camped in the other field! Thought I spotted your van but wasn't sure if it was the one off here. Looking bang on by the way ImageImage.
How did you get on in the race? First one I've done up there, really enjoyed it! Although it'll be too soon if I see another push up or greasy tree root again.... Image
Hopefully that was my last weekend kipping on the floor of the van, should be collecting a tilt and slide bed from Flatout campers this week all being well! ImageImageImage
Sent from my HRY-LX1 using Tapatalk
Caddymaxi13
Post by Caddymaxi13 »
Thanks mate
It did get quite a bit of attention
Erm well I survived which was the main thing haha
I didn't do that well to be fair but I had no injuries and didn't come last, but I completed it which is what I set out to do
Jdot2K
Post by Jdot2K »
Looks great on those wheels.
Caddymaxi13
Jdot2K wrote:Looks great on those wheels.
Thanks mate
Caddymaxi13
Clutch pedal went to the floor on my way home from work, managed to limp it home.
Had it recovered to my mates garage, replaced the slave cylinder, made no difference so everything is pointing towards the master cylinder now ImageImage
I reckon that's about 6 clutch master cylinders I've heard of which have failed in the last week.
Should be an easy fix.
Caddymaxi13
Doc wrote:I reckon that's about 6 clutch master cylinders I've heard of which have failed in the last week.
Really? Well hopefully this is the issue
Is there an upgraded master cylinder available to buy at all? Or anything else that’ll fit? As Doc says, it’s quite common. I’ve been a victim of it myself. I think the whole body cracks.
Gazear
Post by Gazear »
Had the same last week master cylinder went. £165
2012 LWB 1.6 101 blue. Not a BG van.
Caddymaxi13
Gazear wrote:Had the same last week master cylinder went. £165
That's not too bad to be fair. I take it that was fitted
I've extended warrenty with mine so that should be covered
Gazear
Post by Gazear »
Yeah that’s fitted my warranty covered £148 of it
Caddymaxi13
Can't argue with that I guess
Caddymaxi13
Update.
Master cylinder fitted and as good as new.
Caddymaxi13
Stayed behind after work one evening with another technician and Fitted windows from camper glass into the sliding rear windows and also the rear quarters ready for holiday on the south coast
Nerv racking cutting holes into your pride and joy ImageImageImageImageImageImageImageImageImage
Caddymaxi13
After 2 weeks of driving visiting sandbanks, Salcombe in Devon then onto caffeine and machine the van drove without any issues
Next up is a brake upgrade
Just unsure what to go for golf r, s3 or something bigger ImageImageImageImageImage
