Hi all, looking for a bit of help.
Caddy Maxi 1.6tdi 2012.
When locking the doors from inside with the button on the drivers door, the drivers side sliding door locks but then unlocks again. If I press the button on the sliding door down and hold it for a couple of seconds it will stay locked.
Locks ok with keyfob when outside vehicle.
Any ideas?
Sliding door lock problem
2012 Caddy Maxi 1.6TDi 102bhp
Re: Sliding door lock problem
Are the other doors shut whilst your trying this?
Clean the contacts and see if that helps.
Yeah all the doors are shut. I’ll try cleaning the contacts - thanks.
I'm having the same issue.
I cleaned up the contacts but that made no difference so took the door card off but couldn’t see anything really. Ended up taking it to a local independent specialist who determined that the lock was knackered and replaced it. Solved the problem with pound notes!
