2011 Pure Grey
Irish-si
2011 Pure Grey
Post by Irish-si »
1.6tdi poverty spec,
A slow work in progress as it’s a daily work van.
Added a set of mk6 golf wheels , solid bulkhead, rear window protectors, Team Heko wind deflectors, multi function steering wheel, auto lights, W8 interior light and dynamic side repeaters so far
It has cruise control from the factory , I have complete set of electric windows from a 2012 caddy , touran seat bases for when I find the right seats , highline clocks to be fitted, front fogs and highline BCM, vibe slick 6 component speakers and apple carplay head unit on the way, rear camera to replace the rear wiper,
It’s due a timing belt soon and then I’ll release a few more ponies from the dead as a dodo 75 bhp engine
More to follow
Fits perfectly in the wiper bung
Subtle
Irish-si
Re: 2011 Pure Grey
Post by Irish-si »
Irish-si
Re: 2011 Pure Grey
Post by Irish-si »
Irish-si
Re: 2011 Pure Grey
Post by Irish-si »
Swcm
The wheel
Irish-si
Re: 2011 Pure Grey
Post by Irish-si »
New plates Day
Irish-si
Re: 2011 Pure Grey
Post by Irish-si »
Mk4 rear lights with a twist 😎
Irish-si
Re: 2011 Pure Grey
Post by Irish-si »
Fitted my mk4 rear lights with a twist
Re pinned the plugs
Fitted and tested, have to get the bottom bar coded in and all he error cancelled, code in the led’s in reverse and fog and turn off the monitoring, van is filthy as it’s on site 5 days a week
Irish-si
Re: 2011 Pure Grey
Post by Irish-si »
Reverse camera finally wired and working
Pastrana
Re: 2011 Pure Grey
Post by Pastrana »
Rear camera location is great! What brand of camera is it ?
Irish-si
Re: 2011 Pure Grey
Post by Irish-si »
Irish-si
Re: 2011 Pure Grey
Post by Irish-si »
Leather touran seats and bases fitted, rear lights coded, and thanks to the Teleporter driver in work a hole in the back left hand door, I’ve upgraded the BCM to 086 and the van is coded for alarm which I have loom and siren , and also front fogs are wired and coded for cornering just need to pass both looms in to engine bay and connect lights and siren
Irish-si
Re: 2011 Pure Grey
Post by Irish-si »
Seeing as this is a working van and on site 5 days a week it’s ballache trying to get lengths of pipe around so roof rails were always on the cards , a set came up for sale fairly local so I had those and fitted today , I’ll fit the crossbars as soon as I have them
Irish-si
Re: 2011 Pure Grey
Post by Irish-si »
The touran seats are heated so I sourced the correct switch panel and will get tommyzoom to make me the loom for heat and occupancy going forward, there’s a bit of messing around with the switch panel for the hot and cold and directional air flow and as can be seen the back panel has to be swapped
More to follow
Re: 2011 Pure Grey
Post by stu_b »
Coming along nicely
Seems like tommyzoom is the man
Wish we had someone like that (as a member) here in Australia 🦘🐨
Thanks for the update and pics
Heated seats would be a luxury
Irish-si
Re: 2011 Pure Grey
Post by Irish-si »
stu_b wrote: Sat Mar 25, 2023 7:37 pm Coming along nicely
Thanks Stu, I’m sure Andrew would send you guys bits
