- Chris_Fz
This looks goods.
Sent from my SM-S908E using Tapatalk
Reason: Removed quote of previous post
-Vw Caddy Pv 2.0TDI 2015 stage 2 + 110wkw / 376nm -
-Nardo Grey & Black Trim
-Rolling on 19" A-line Hostiles
-Owner of Retrofitters
-+2771 027 5064-
-+2771 027 5064-
- AusCad
Some really nice detail in your cabin. Magic place to be for you now.
It would be so nice to have accessibility to Touran parts in AUS.
Fantastic work! It’s a great thread to follow.
- Raph71
Re: Un Bon Caddy
Vraiment sympa Caddy !
Je n'oserais plus aller pêcher avec!
Hi Ralph,
Thanks very much. I couldn't imagine going fishing without the van, I get to combine my 2 favorite hobbies into one
Wiring harness completed for push buttons for Park Assist, Tire Pressure and Electronic Stabilization. Everything wired per the VW Current Flow Diagrams.
Seen a CANbus extension harness on Ali Express so thought I'd get it and see what it was like, saves soldering. The 3 black plugs on the extension cables were crappy 3 pin ones so I took them off and put on some genuine VW 2 pin ones.
Installed a 5pin connector in the harness for the Scirocco gage pod, make it a lot easier to take in and out if needed.
Hi fishermansfriend what a mint caddy you have built there , hats off to you, just a quickie regarding the van style arch kit you fitted , are they just double sided taped on ? Are they a nice fit, I,E no gaps ets ?
Thank you Dale. I didn't like the fit of them out of the box, the gaps were to big. The instructions say to glue on and they have double sided tape also but I didn't glue mine. I took the tape off and messed about with different thickness of tape before I got a fit I was happy with.
Thanks for the reply mate , and keep up with the great work , tight lines ….
I didn't install the buttons/ wiring yet, I was looking for the correct connectors for the push buttons. After going through all the different colors I found the correct ones that fit without trimming the connector to make it fit, (1) 8W0971636B for the TPMS and (2) 8W0971636D for Park Assist/ ESP are the correct connectors.
Stunning
