What's this part on egr
Daggz68
Post by Daggz68 »
On another engine I've seen something similar on top of the egr valve. On YouTube someone has done a cheap egr delete by pulling out one of the pipes to it and blocked it off https://youtu.be/cBuJlNPh_xY
Now on my bls engine it's different and just wondered if the part circled is the same thing and can I pull the pipe off just the same as in this video and map it out using vcds?
ThanksImage
Sent from my NTH-NX9 using Tapatalk
Re: What's this part on egr
That's the VNT actuator for your turbo.
Daggz68
Post by Daggz68 »
Doc wrote:That's the VNT actuator for your turbo.
Thanks. Not sure if it's the same as the bit in the video then
