Time to start a new build. Ex BG maxi. Hereford.
MWMRacing
Re: Time to start a new build. Ex BG maxi. Hereford.
Post by MWMRacing »
Amazes me the level that BG went to while fitting out their caddys, love the colour as well- most setups here in Australia for government is Toyota Hilux's or Toyota Hiaces- looking forward to continue seeing your progress with this.
2013 Caddy Runner- 66KW manual- 2007 SWB Diesel- currently being converted to TFSI
Nicklouse
Post by Nicklouse »
The Rhino rack had to go. And is now available.
The BG aerials are gone. Holes filled with Rivnuts
Great positioning.
Nicklouse
Post by Nicklouse »
Today has been another one of learning the BG Van foibles.
Had this on the fuel filler. It only allows a diesel nozzle to fit and open the flap. Wanted to add some additive and was also concerned about emergency refilling.
Asked in Caddy chat and got some great info.
Front passenger seat out. Rummage at the bottom of the B pillar
And
Apply some force to the yellow thing and it unscrews
Check key works and
Sorted.
TheGrinch
Post by TheGrinch »
I know this paint color is relative common in the UK but man I never see this blue in DE :cry:
Nicklouse
Post by Nicklouse »
Seen a few comments about people not being able to open the rear doors with a trailer on the back.
First time using my trailer with this van.
Not a problem
Doing what I need it to do.
Nicklouse
Post by Nicklouse »
Having a sort out and threw the seat cushions that I had made for the T4 in the back of the caddy.
Will be used in this build.
Jay586
Post by Jay586 »
Interesting thread. I've been looking at ex-BG vans, love the colour!
Nicklouse
Post by Nicklouse »
This van has a fresh MOT. There has been a bit of a bang at the rear. Thought ARB bushes. But when I grabbed a shock I could see it was worse. One is a fail and the other an advisory. They were not actually leaking but WTF.
New set on after work and before Gin O’Clock what a difference.
DW2207
Post by DW2207 »
I don't know what your worried about, those shocks look fine to me. A bit of hammerite paint and they are sorted
Nicklouse
Post by Nicklouse »
Todays little win. Bulb out warning on dash. Every seemed to be fine. But there were no DRLs on. Change bulbs warning light goes out. VCDS tells me they have been blown since 2017!
Yesterdays loss. One flat tyre = 2 new front tyres.
Nicklouse
Post by Nicklouse »
Today.
Cut out the finishing parts of the passenger side of the bulkhead. Need to loose more of the edge.
Then it was time to see where I might fit the “leisure battery”
Currently used to start the race car and power the amps.
Most likely swap it out for a proper AGM of the same physical size.
Nicklouse
Post by Nicklouse »
The last two weeks have seen a bit of planning.and wiring.
New head unit fitted.
One amp provisionally fitted. Needs a board as there in another to be fitted for the sub.
Box speakers just on the floor.
Cable run for the head units rears.
USB port fitted fit the phone.
Phone mount missing in post as I received someone else’s order.
Cable run for the split charge. The VSR will be mounted where the old BG cut off switch is.
Nicklouse
Post by Nicklouse »
One more rattle and bang sorted.
Rear ARB bushes changed.
Speaker wires added to the Quad lock for the rear upper speakers.
Just need to sort the high level brake light and reversing camera.
Then it will be time to get some structure in it for seats sink and storage.
Oh might fit the TV tomorrow.
Nicklouse
Post by Nicklouse »
New phone holder fitted along with a short cable . Aux input added. Will run the rear view camera cable tomorrow then I can put the trim back in.
Nicklouse
Post by Nicklouse »
Well well I have seen some instructions in my time but this takes the biscuit.
Going to have fun running the new auto lights sensor and finish off wiring the front fogs.
