3.2 v6 DSG conversion
Pineapple1984
Re: 3.2 v6 DSG conversion
Post by Pineapple1984 »
So there aren’t any “pin out” diagrams as far as I know. What you’ve got to do is print out the wiring diagrams as you’ve done then study both cars carefully your notice some stuff is like for like eg t14 plug pin 1 oil pressure switch is the same as caddy as is t14 pin 9 (Earth) (eg only)
The best way I found was to do the theory and then just follow your instructions!
I will warn you it’s not a quick task. It’s always hard to portray exactly how involved the wiring is with a few pictures on here but it’s a LOT of work! But mega when it all comes together
My 3.2 conversion viewtopic.php?t=53703
NZDubNurd
Post by NZDubNurd »
Yeah! What he said^^^
VW diagrams are quite different to what japanese makers use! They info is there, but you have to change mindset to "get" it!
https://forums.ross-tech.com/index.php?threads/1875/
youtu.be/jKnTjuSmwaE
youtu.be/bMn0i-yHhSA
I replied to your PM, btw.
Damo2k
Post by Damo2k »
Thatnks lads much appreciated.
Q
Poffe
Post by Poffe »
Pineapple1984 wrote: Mon Sep 18, 2023 9:52 pm Image
Steering control module HIGH installed for paddles and multifunction steering wheel
Thinking about getting a steeingwheel with paddles installed on my car.
Do you know what partnumbers you used for steering control module you used?
Oem partnr on the steering wheel Im thinking to use are 5K0419091AG, from a Golf GTI -12.
Really nice and interesting build! Im mostly impressed with your patience on the wiring work and you cleaning abilities :D What do you use for cleaning except elbow grease?
Pineapple1984
Hi @Poffe
I used a steering column ecu from a 2012 golf GTD, pt number 5K0953549B.
Depending on your spec of vehicle your need to change the stalks if you have MFD buttons on your stalk as it will conflict with the multi function steering switches!
Your also need to code J519 accordingly depending on your spec but that’s pretty simple.
This is what I done with mine anyway and that’s a 2011
Hope this helps.
As for cleaning the long and short answer is a load of elbow grease and a lot of prep before painting! I’m very sad, as you may have guessed 🤣
Pineapple1984
Touran dash now going in! And got myself a R style instrument cluster.
Pineapple1984
Sound deadening and heated seats wiring loom going in.
Poffe
Post by Poffe »
Pineapple1984 wrote: Wed Nov 22, 2023 8:49 pm I used a steering column ecu from a 2012 golf GTD, pt number 5K0953549B.
Thanks! Straight and simple answer! I like it.
Pineapple1984 wrote: Wed Nov 22, 2023 8:49 pm Depending on your spec of vehicle your need to change the stalks if you have MFD buttons on your stalk as it will conflict with the multi function steering switches!
That I had figured. Need to find some on a local scrap yard.
Pineapple1984 wrote: Wed Nov 22, 2023 8:49 pm Your also need to code J519 accordingly depending on your spec but that’s pretty simple.
That I didn’t know! Guess I have some ready up to do on how to!
Pineapple1984 wrote: Wed Nov 22, 2023 8:49 pm As for cleaning the long and short answer is a load of elbow grease and a lot of prep before painting! I’m very sad, as you may have guessed 🤣
Sad wasn’t the first word I thought of😂 anyway, crazy amount of stubbornness/patience 😉
