Damo caddy build
- ToiletTFSI
Re: Damo caddy build
do you you have the unpick tools?
- C Chis
Awesome! I love a good wiring harness!
- Damo2k
@ToiletTFSI yea have a set from amazon seem to be doing the job so far...
- Damo2k
@C Chis your welcome to it mate
Wenty93
Looks smart deffo going to be a flyer
- Damo2k
Thanks mate,that's the plan anyway
- Damo2k
Painted and fitted the r32 front brakes.
Now to get the rears done..
Bgd99
what are the wheels? and spec of them
- Damo2k
Ttrs twists
19" 8.5 et45.
19" 8.5 et45.
- Damo2k
Just about done with the clean up of all r32 subframe,steering rack ect,incl all new parts incl passat aluminium arms,
Onto the hubs tomoro for clean up,paint and new wheel bearings,
- Damo2k
Thinking of swapping out my caddy cluster for the mk5 golf r32 cluster afaik this can be done by changing the other casing?
Does anyone know if its possible to have a full colour mfd added to the r32 cluster ?
Any help would be appreciated
- Damo2k
What's best method for vr6 swap battery relocation?
As in best place to mount it and what you actually use to mount it?
Thanks.
Thanks.
- Damo2k
Few jobs today on the r32 engine to hopefully have it fitted to the caddy next weekend...
New clutch fitted.
New waterpump.
New rad couplings on coolant hoses.
Made a plate to blank off the sai pump.
Air con delete.
New spark plugs.
All cleaned up and ready to go..
New clutch fitted.
New waterpump.
Air con delete.
New spark plugs.
- Damo2k
So trying to fit my r32 pedals to caddy but the accelerator body seems to be completely different to the r32 one iv read on here that you can swap over the throttle body base to the caddy but the r32 hasn't got the plastic hook (lever) as the caddy??am I missing something here?
- Damo2k
After some research I think there may be 2 different types of pedals for the caddy?
1t2 721 503 h is what is fitted to my caddy.
2K5721503E is what I need.
Think maybe cause my van is 2011 it has the older non face-lift pedal?
