I purchased the proper designed VW Caddy under seat subwoofer box from CEN Automotive, was around £120 with Christmas sale but still quite expensive.
Anyway they only fit 10” sub and I wanted my previous 12” sub fitted and wanted the amp controller mounted with it also so… set about hacking up the nice new sub box! Now suitable for a much bigger subwoofer.
I had quite abit of blue tartan left over from doing the door cards so figured I’d use it for the sub box. It was getting cold and dark, knew it would never be seen again and didn’t have the patients to cut and join it a million times so just quickly covered everything is sight and fitted the actual important bits… the sub and amp!
And then fitted it in place.
The floor area was also covered in sound deadening DoDo mat before dropping it in place.
I didn’t want it on permanent / via an ignition live like most systems are so wired it to work via the heated rear screen button as it’s redundant and not connected to anything in my van. So ran the remote switch wire to the relay behind the dash.
All connected up and working so can just switch the sub on / off whenever I want without any hassle at all, the results of everything together….
AMAZING! if you enjoy music this should be top of your upgrade list, for around £500 will transform it from dull standard speakers to top of the range premium range that shake the full van on full bass.
2019 Caddy Highline, Heated screen, parking sensors, cruise, auto lights, virtual cockpit dash, custom blue seatbelts, heated GTE seats, GTE MFSW, climatic, rear camera, discover media nav, oem+ led headlights, GTE tartan doorcards, Audison sound system (project: highest spec highline
