Damo caddy build
ToiletTFSI
Re: Damo caddy build
Post by ToiletTFSI »
do you you have the unpick tools?
C Chis
Post by C Chis »
Awesome! I love a good wiring harness!
Damo2k
Post by Damo2k »
@ToiletTFSI yea have a set from amazon seem to be doing the job so far...
Damo2k
Post by Damo2k »
@C Chis your welcome to it mate
Wenty93
Post by Wenty93 »
Looks smart deffo going to be a flyer
Damo2k
Post by Damo2k »
Thanks mate,that's the plan anyway
Damo2k
Post by Damo2k »
Painted and fitted the r32 front brakes.
Now to get the rears done..Image
Bgd99
Post by Bgd99 »
what are the wheels? and spec of them
Damo2k
Post by Damo2k »
Ttrs twists
19" 8.5 et45.
Damo2k
Post by Damo2k »
Just about done with the clean up of all r32 subframe,steering rack ect,incl all new parts incl passat aluminium arms,
Onto the hubs tomoro for clean up,paint and new wheel bearings,Image
Damo2k
Post by Damo2k »
Thinking of swapping out my caddy cluster for the mk5 golf r32 cluster afaik this can be done by changing the other casing?
Does anyone know if its possible to have a full colour mfd added to the r32 cluster ?
Any help would be appreciated ImageImage
Damo2k
Post by Damo2k »
What's best method for vr6 swap battery relocation?
As in best place to mount it and what you actually use to mount it?
Thanks.
Damo2k
Post by Damo2k »
Few jobs today on the r32 engine to hopefully have it fitted to the caddy next weekend...
New clutch fitted.
New waterpump.
New rad couplings on coolant hoses.
Made a plate to blank off the sai pump.
Air con delete.
New spark plugs.
All cleaned up and ready to go..ImageImageImageImage
Damo2k
Post by Damo2k »
So trying to fit my r32 pedals to caddy but the accelerator body seems to be completely different to the r32 one iv read on here that you can swap over the throttle body base to the caddy but the r32 hasn't got the plastic hook (lever) as the caddy??am I missing something here?ImageImageImageImage
Damo2k
Post by Damo2k »
After some research I think there may be 2 different types of pedals for the caddy?
1t2 721 503 h is what is fitted to my caddy.
2K5721503E is what I need.
Think maybe cause my van is 2011 it has the older non face-lift pedal?
