1.6 TDI VDO Injector failure root cause analysis
nathanjones916
Re: 1.6 TDI VDO Injector failure root cause analysis
Post by nathanjones916 »
Ye thats great, that was what I was hoping to hear. Think will just have to go for it and hope for the best, at least with buying new get 2 years guarantee with them.
Sent from my SM-G970F using Tapatalk
BenT
Post by BenT »
Another day another dud injector for me... This time going down an incline at 50 mph with only slight accelerator pressure. It lost power and stuttered for a few seconds before the glow plug light started flashing. It's the #2 injector, which I replaced with an 03L130277S 2 years (17,000 miles) ago. The injector was second hand, but only 2 years old from the date stamp at the time I bought it so I assume it's managed less than 40 k miles overall. Pants.
Anyway, when I have time I'll hack it apart to try to see what the difference is between this and the B variant. This might give a clue as to the failure cause. Not that it really matters... As a final hack, I'm going to try unscrewing the piezo actuator in-situ and replacing just that, without removing the whole injector, Just to see if it's possible. This would make it a far easier road-side fix.
Meanwhile, my #1 injector's on 165,000 miles now and still going strong. How is this possible?
Simon46
Post by Simon46 »
Done all 4 with brand new S type no problems for years now
66 plate mk4 1.6tdi with prosport coilovers
235/35/19
2011 1.6 102ps wolfsburg ex BG now sold
1. remapped to 140 egr delete hyperchips then
2. Remapped to 150 egr delete celtic tuning with EA189 update yuk
3.
Roof rails sidebars colourcoded mirrors Bumpers roofspoiler
Android dab head unit with passive underseat sub
Van-x glovebox and cruise control and rear barn door interior handle fitted
Vanmandan
Post by Vanmandan »
Friday injector 3 went on me, AA recovered and replaced for £802 using genuine parts. From what the mechanic said the AA parts and garage cover will cover up to £500 of the repair. This seems to be the be option for the issue
Was it electrical or mechanical failure?
ransomz0
Post by ransomz0 »
Number 3 went yesterday. Luckily I was only 5 minutes from home so was able to nip home and replace it.
Does anyone recommend reconditioned units and a place to buy from?
Caddy Maxi C20 Startline 1.6TDI 2015 Mk4 facelift
Ex BG
BenT
Post by BenT »
I was reading a research paper the other day that suggested the piezo stacks on these injectors could be regenerated; I don't know how "reconditioned" injectors are actually reconditioned though.
It might be worth just keeping an eye out for second hand injectors with a recent production date stamp - sometimes these can be had quite cheaply.
Bahnstormer
Post by Bahnstormer »
ransomz0 wrote: Sat Aug 24, 2024 9:56 am Number 3 went yesterday. Luckily I was only 5 minutes from home so was able to nip home and replace it.
Recon injectors aren't worth the time or money, you'll just end up replacing them again 6 months later.
Buy new from PF Jones, they're much MUCH cheaper than VW but are the exact same product https://www.pfjones.co.uk/volkswagen-ca ... 40080.html.
ransomz0
Post by ransomz0 »
Thanks for the feedback. Do you know if the Continental branded parts are identical to the Siemens ones i e.. is it the same production line?
Ex BG
Bahnstormer
Yeah, I'd imagine so, Continental own Siemens VDO.
ransomz0
Post by ransomz0 »
Well, a couple of days after injector 3 going number 1 followed suit. I have now gone through 6 injectors over the last three years and haven't covered much over 10k miles.
Enough is enough and I've got rid of the pile of sh1t today....
Ex BG
BenT
Post by BenT »
Sorry to hear about that... were the failed injectors reconditioned, second hand or new when they were fitted to your van? Not that it's your problem any more!
ransomz0
Post by ransomz0 »
Always new Continental, Siemens VDO or VW
Ex BG
eva69
Post by eva69 »
Can I ask if you replaced any ‘incase’ they went after the first two needed replaced?
Is this something worth doing after two of mine have gone within 6 months on the same model as yours.
ransomz0
Post by ransomz0 »
No always replaced as required. I've sold it now due to the ongoing expense and extreme inconvenience
Ex BG
