Damo caddy build
Re: Damo caddy build
The pedal should separate and then the R top piece can go onto your caddy lower piece. The lower pieces are different as the Caddy and golf have different positions for the pedal.
- Pineapple1984
As Doc said you can slide the R aluminium piece out of the side if you separate the plastic part stopping it coming out and slide it into the caddy body then it all fits
My 3.2 vr6 supercharged conversion viewtopic.php?t=53703
- Damo2k
Thanks doc so I tought but looking into it my caddy pedal is completely different and don't think the R one will fit it...unless mine is from a touran or something?even backs of the top part of pedals are completely different if you know wat I mean..
- Damo2k
Thanks @Pineapple1984 maybe I'm looking at it all wrong then
I will take another look tomorrow as I put it back in the van thinking it was wrong..thanks lads..
I will take another look tomorrow as I put it back in the van thinking it was wrong..thanks lads..Sent from my SM-G986B using Tapatalk
- Pineapple1984
Il take some pics of mine tomorrow mine was out of an eos iirc
- Damo2k
Appreciate it mate if u see in these pics the R pedal has not got the lever on the back like the caddy one
- Pineapple1984
Ah yeah looks like the R pedal may have a different hinge too
- Damo2k
Yea it does mate the caddy one is on long pin going through the pedal and body and R one slides out the side..
- Damo2k
Strange maybe one the previous owners switched out my pedal before?ah well back to the drawing board
- Damo2k
Didn't get to start my engine swap this weekend as could not get the time off work so have booked few days off on 11th to get it done...
In meantime have done few bits.
Purchased some caddy life b pilar trims,got them fitted looks good,also fitted auto headlight switch and module,
My r32 look rear bumper has arrived and I also got myself a hybrid vaddy front bumper mk 7 gti welded to caddy bumper just to get them painted now.
Av also got my tank ready with r32 pump fitted and new regulator (filter)
snuffegull
- Billy.2kcaddy
Damo2k wrote: ↑Fri Mar 10, 2023 9:21 pm So this turned up today after a long searchordered loom from tommyzoom so will be nice to finally have some heated seats in the caddy
Hi mate,
build is awesome! im after one of these panels for my caddy to. where did you get yours from in the end?
- Damo2k
Hi mate I think it was from a Turkish website just kept searching Google with the part no until something popped up
- Damo2k
3 hour round trip this morning to pick up my bumper.
- Damo2k
And then it had to happen
