@mark1a @Philnanks
Would either of you be able to tell me what size spline bit is needed to remove the bolts for the bars?
Removing roof rails
- mark1a
Re: Removing roof rails
Hello, have just found the bolts from my old roof bars, and can't for the life of me find the tool I removed the bars with. It's obviously a torx drive of some sort or similar, but none of mine fit. From memory I think I was round my mate's place when I took mine off and probably used something out of his garage.
Sorry!
Sorry!
- Giddy
OEM bolts are M8 spline.
XZN Triple Square
Can't tell you the size though
- Bad666
Hi I’m just trying to remove my caddy maxi roof bars exactly the same. I’ve removed end pieces and bolts but they won’t shift . No caps for screw in middle how do you release ?
- Sag1
Removing roof rails
@Bad666 - The middle cover pulls out away from the vehicle.
Edit: Check this thread
How to remove/fit OEM roof bars
https://r.tapatalk.com/shareLink/topic? ... source=app
2106 Caddy Life 1.4 TSI | Wheelchair Driver | My Instagram
- Bad666
Thanks! this is what I was looking for, stumbled on them after tapping about for plastic instead of metal. All done now.
any helpful information how to remove the roof rails on a 2021 (SB) model?
cant get around how to remove the front and rear "caps" to get to the bolts...
- azauhar
Could somebody please post a picture of the roof rack mounting area when OE roof rack is removed? Thanks.
