snuffegull
Thank you! I do enjoy working in a body shop, but it can be frustrating at times
gorelimey
This thread is great and I'm not even halfway though it yet.
Hi gorelimey, welcome to the forum and thanks for taking the time to have a read through it.
Jeff84
What an incredible build thread
Thanks very much Jeff84 and welcome to the forum.
Luiscunha89
Hello. Were you able to solve the problem of closing the glass with this module?
Hello, I didn't use the Passat modules. I ended up using the Scirocco ones that were already installed, they worked fine. Window one touch is not working so I do plan on installing the Passat modules soon, I have read that if you put down the window and unplug the connectors from the door control module and reconnect and then do the memory reset steps that it will work?
Custom gloss black Central Lock kit from MG-Line for OZ Ultraleggera HLT wheels I got going on soon.
New set of 6pot Akebono 8N calipers from BrakesKing in the works, currently working on shaving 2mm of the side of the calipers so they fit behind the new wheels without having to use spacers. Gonna have them finished Porsche Speedgelb 12H.
I got some spare caddy door cards recently so I did a bit of cutting and sanding to try and retrofit VW OEM door warning lights I had bought. They sit flush with the face of the door and clip in at the back by adding 2 plastic strips which I have glued to the back to the door card. The side is red light and the bottom is white LED.
Imprintx
Great job buddy, looks class !!
Thanks buddy, will I order you a set?
Imprintx
New set of 19" OZ Ultraleggera HLT gloss black wheels 9,17kg each.
3rdLeg
Nice, man!
Width and offset?
Width and offset?
