Swan’s caddy build
Sean1066
Re: Swan’s caddy build
Post by Sean1066 »
Looking good there Peter.
You going blue and black or just blue?
Caddy maxi 3.2 VR6 EX BG
My build thread
Thanks Sean.
Going blue and black on the engine cover mate, blue on the other bits.
Basically, I’ll be copying how you did yours
Sean1066
Post by Sean1066 »
You will be making hybrid bumpers and doing an engine swap next 😂
My build thread
Sean, you should be on the stage mate. You’re hilarious
Bit more progress made today. Got the parts colour coded and lacquered.
I haven’t lacquered the centre of the engine cover yet as I want to highlight the VW badge and TDI lettering. Image
Sean1066
Post by Sean1066 »
That looks awesome Pete.
Very nice work indeed 👌
My build thread
Cheers Sean. First time I’ve really sprayed anything apart from the odd bracket or similar.
Can’t wait to see the bits fitted back on the van
Handyandy
Post by Handyandy »
They look great Pete
Cheers Andy. I’ll be able to open the bonnet at Tatton now
Post by stu_b »
Did u have to use special paints to get that lovely finish ?
Cheers mate.
No, I just rubbed them down, 2 coats of primer, flat back and then 1 more coat. Then 2 coats of paint, flat back then 1 more. Then 2 coats of primer. All bog standard stuff mate.
Handyandy
Post by Handyandy »
I take the engine bay is getting a good spruce up to make it look more presentable keep up the good work
Swan’s caddy build
@Handyandy, yeah I thought it was about time I did a bit underneath the bonnet mate.
Got all the recently painted bits fitted now. I’m happy with the results, and I think it looks pretty good! Image
More to follow…..
Sean1066
Post by Sean1066 »
That looks awesome there Peter. You smashed it 👌
My build thread
Cheers Sean!
