Blackberry Life
mark1a
Re: Blackberry Life
Post by mark1a »
Hello and thanks for your comment.
I do still have this Caddy although I’ve gone from running it 18k miles a year in the beforetimes to 3-4k miles a year post-pandemic due to work being permanently based at home now.
Only update this year is the head unit replaced with Alpine iLX-705d (great unit) with the canbus unit for better integration. I was going to post about it when I got round to fitting the Vanstyle curtain set at some point.
Anyway, the rear suspension is stock factory Maxi Life, not sure whether it’s the double or single, but it’s definitely the softer option. It’s been fine although it occasionally bottoms out or hits the stops when loaded up a bit. My plan was always to look at this when either the shocks and/or bushes needed doing, and then upgrade front & rear springs then. However this is taking longer due to the much lower mileage.
Good luck with yours and thanks again.
edgarjessop
Re: Blackberry Life
Post by edgarjessop »
mark1a wrote: Sun Mar 07, 2021 6:16 pm Rack is this one:
http://www.minoura.jp/english/transport ... o-tf2.html
With optional wheel holder:
http://www.minoura.jp/english/transport ... pport.html
I also have this for 2x bikes:
http://www.minoura.jp/english/transport ... sb-10.html
All above is fine for 9mm QR, I think it's possible to use with thru-axle but it wasn't straightforward so I got this for the thru-axle forks:
https://www.amazon.co.uk/gp/product/B00 ... te_s_rp_ti
All perfect for road & gravel bikes, but a bit lightweight for the 29er FS eMTB, so for that I use this with tie-down straps.
https://www.amazon.co.uk/dp/B071RC7BP9/ ... _pc_tf_til
I've just bought a 2019 Blackberry Caddy Maxi and also need to transport a 29er FS eMTB, but can't get the last Amazon link to work. Do you have a more recent link, or photo/description of the rack? Thanks
mark1a
Re: Blackberry Life
Post by mark1a »
Hello, try this one:
Bike Floor Stand - Heavy Duty Bike Stands for Storage - Bike Stand Suitable for Indoor & Outdoor Bicycle Parking - Bicycle Storage Rack for Kids/Road/Mountain Bike Wheels https://amzn.eu/d/izsmvk6
Original link is 5 years old now, but new one above is similar.
edgarjessop
Re: Blackberry Life
mark1a wrote: Sun Nov 10, 2024 12:27 pm Hello, try this one:
Thank you, will get that ordered
Mukki77
Re: Blackberry Life
Post by Mukki77 »
mark1a wrote: Sat Nov 09, 2024 5:54 pm Hello and thanks for your comment.
Hi thanks for the reply.
i now got into the Situation with the rear suspension. Mine got the double leaf spring option since the preowner put a Trailerhitch on the Caddy. Since i do not plan on towing anything heavy i might put single leaf spring back on. But since you have the same thing that with some little load it hits the stops etc. i might go to better Shocks first.
If you want to upgrade to double rear springs ... i have them on and its basically the same situation as yours when loading up a bit.
Lets see how we can solve this soft rear :-)
Thanks Mate :-)
BR,
Torsten
Teccyjim
Re: Blackberry Life
Post by Teccyjim »
Getting some crazy ideas for my 2011 Maxi Life, just from reading this entire thread. My T5 lower half is painted blackberry (silver upper) so I knew this would turn out well! There's no better colour in the sun!
mark1a
Re: Blackberry Life
Post by mark1a »
AdBlue light back on and won’t go out after top up, this is the third time this has happened, and VW advise it needs a new AdBlue sensor (only available as part of the entire system) at a cost of £1116 inc vat and labour. Booked in next week, a bit annoying but in 8 years, nothing (other than a NOx sensor) has gone wrong and other than routine servicing and consumables, it’s been a really cheap van to run.
mark1a
Re: Blackberry Life
Post by mark1a »
Quick update... AdBlue tank changed and all good so far...
The Santiago wheels were starting to get a bit chatty around the spokes, the lacquer had peeled in places and water had got in.
I've just had the tyres swapped over to a set of 18" Estorils in black.
Makes for a different look I think, I'll get used to it...
juliang71
Re: Blackberry Life
Post by juliang71 »
One of, if not the first build thread I read after getting my Maxi Life. A really good read, proving less is often more!! Have it bookmarked and stole a few ideas and mods for mine that have already been done. Maxi Life's are great looking vehicles.
Tempted to remove my roof rails now :D
mark1a
Re: Blackberry Life
Post by mark1a »
Wow thanks. Yes, less is more, aiming for OEM+ look, i.e. something resembling what would have been had VW ever made a sportier Caddy Maxi Life.
Roof rails - I had never used them, and haven't missed them since they came off. Very simple job once you have the correct blanking bolts and if you kept them, they could always go back on if you needed them.
ben120280
Re: Blackberry Life
Post by ben120280 »
Love this….. lots of inspiration, thanks 🙏🏼
