Oh that's nothing! ImageImageImage.....Image
:shock:
Ooooo !
That's nice
:D
Thanks mate, it's a relief they worked out!
Looking good 🤘Image
Sent from my Pixel 9 Pro XL using Tapatalk
Rock On Gazza
Only way my DRLs work currently 🤣🤫
the67al
Post by the67al »
Fitted this RAMAIR proram kit
Oaky1965
Post by Oaky1965 »
My caddy’s just gone in to be lowered at CRS
Oaky1965
Post by Oaky1965 »
I’ve just had it lowered at CRS Performance Koni coilovers and axle flip
Looking good
:D
Oaky1965
Post by Oaky1965 »
Slowly getting there
mac12
Post by mac12 »
Swapping my rear calipers tomorrow. Any tips or tricks or stuff I should keep in mind? Rotors and pads were changed a month ago, I'm also changing the slide pins as I go along. I've got a bleeder kit with a one way valve as well as a brake line clamp so I should be able to bleed them by myself.
mac12
Post by mac12 »
Went well for the most part, right rear brake pipe from brake line to caliper snapped as I was unwinding it. Should have let the penetrating oil work a bit more, rusted as hell in there. Managed to make a plug from the old broken hose, so it won't leak while I'm sourcing a new pipe. Think also I might have cross-threaded the left hand caliper brake pipe. Went smooth for a couple of turns and then I had more resistance. Hopefully just dirty threads. Got it seated nicely in there, didn't leak as I was bleeding it but we'll see when the engine is on and servo is involved.
Leeroy80
Post by Leeroy80 »
Hello sorry, this is my first post. In case im doing something wrong. Just put deposit down on 2018 maxi life and hoping to add android auto and a rear parking camera.. it looks like you had the same existing head unit.. what model did you get?
Many thanks
gazza31112 wrote: Sun Feb 09, 2025 1:51 pm New JVC android auto head unit Image
davoc220
Post by davoc220 »
After fitting the Bi-Xenon headlights, on Saturday, been struggling to get them coded, on the plus side Iv coded enough to actually have lights, always a bonus on nightshift!! Also fitted the door modules to get the folding mirrors working as the switch arrived on Saturday as well, but they won’t code either, so getting pro help when I get home on Friday, tho I can get the beam lined up, at present their looking for snails 6ft infront of the bumper
