Scotscad
Post by Scotscad »
If its any help with colour coding i found the spray tin of candy white from the range is a better match than halfords. Found halfords paint a bit on the yellow side of white.
Transitionpilot
Post by Transitionpilot »
Scotscad wrote: Fri Sep 26, 2025 7:50 pm If its any help with colour coding i found the spray tin of candy white from the range is a better match than halfords. Found halfords paint a bit on the yellow side of white.
Lmao!, I had no idea they sold it in there! and there's one next to my halfords store - I figured I'd use the halfords one as a base coat and then get some proper vw paint for the last few coats, paid £18 for what can only be described as a 'fun size' can from my local dealer!
davoc220
Post by davoc220 »
Fitted my A5 seat yesterday , others going in today and have the airbag light on, nightmare! Obd11 says voltage is high on thorax bag, think I need an auto spark
STP
Post by STP »
davoc220 wrote: Sat Sep 27, 2025 9:33 am Fitted my A5 seat yesterday , others going in today and have the airbag light on, nightmare! Obd11 says voltage is high on thorax bag, think I need an auto spark
Did you swap the seats with the battery connected...
davoc220
Post by davoc220 »
@STP
Yes, ignition was off the full time, have a feeling I haven’t wired the plugs correctly, on the drivers side there’s 3 wires, on the oassengers theres 5 on the seat sides, on the body loom there’s 3 on the caddy
Flog_TSC
Post by Flog_TSC »
Removed seats and center console gave it all a clean and general tidy as previous owner hadn’t bolted everything up quite right
Also fitted a compact sub under the passenger seat
mirogo
Post by mirogo »
Good morning everyone,
Last weekend I insulated my floor in the cabin and retrofitted a Touran Mk1 carpet, next step is a touran center console with armrest and then door insulation include new speaker set.
Bienie
Post by Bienie »
gave her a good deep wash. well needed after 2 weeks in Norway!Image
STP
Post by STP »
That looks nice, I started looking for a Touran front carpet set on eBay but people are asking £100 for them on there. Bloody cheeky.
Marcelorider
Post by Marcelorider »
I’ll be quite honest I haven’t read all the posts, are there any recommendations in terms of must have mods for the caddy?
son of eevil
Post by son of eevil »
Pulled the EGR and throttle bottle and that pip that connects both to the intake manifold
Gave both a good clean up of all the built up sludge.
Am debating pulling the intake manifold so that I can clean it too... But it's so many new gaskets I need to buy.....
About 3 EGR gaskets, exhaust gasket, intake gasket for like $200 worth of gaskets...
I REALLY want to clean it... But also, I don't want to spend $200 on gaskets when I am already 2K deep in parts and refurbishment....
STP
Post by STP »
The entire intake will be choked too. I wondered about the cleaning system that Edd China was advocating, if it could get rid of the amount of sludge built up. I've personally seen Citroen HDi engines stripped down and the intake runners had been reduced from 38mm down to about 15mm due to carbon sludge build up and it's a wonder the engine even runs at that point.
Flog_TSC
Post by Flog_TSC »
Mapped the maxi now actually flies im well
Impressed with the little 105 engine not sure what bho it is now but all good
Couldn’t get into the security using vids to take the limiter off tho not sure why
son of eevil
Flog_TSC wrote: Fri Oct 03, 2025 6:31 am Mapped the maxi now actually flies im well
Big difference then?
Any change to the fuel efficiency?
son of eevil
Pulled the intake, exhaust, turbo, gearbox and DMF off.
