STP
Post by STP »
Low battery voltage can do strange things on a modern vehicle! ECUs act crazy when the battery is poorly.
Best Caddy & Transporter upgrade content on YouTube: DTETV
The Fan issue must have started the battery low situation as I had driven the day before so the battery should not have been really low.
Just have to wait and see what happens over time
Thanks for your help.
Poffe
Post by Poffe »
STP wrote: Thu Jan 01, 2026 11:29 pm It seems you can't get rid of the bulb error with VCDS or Obdeleven. Only VCP can do it (Vag Can Pro) and that will ONLY run on Windows 7x32 bit and nothing else (believe me I've tried) and is also dangerously powerful.
You need the kit from AliExpress with the license dongle and then need to watch the videos on installation. Antivirus goes mental when you try to install it, takes nerves of steel and not on a machine you use for internet banking for example.
It does not work in a virtual machine, or windows 10 or 11.
Thanx! Just got my Vag Can Pro home, to run on my diagnosic laptop (Windows XP). Hope it will work. Although, changing anything in the BCM coding seems to be a huge risk and when ever I read something about it there is always clear warnings.
Anyone have a decent description on how to do the coding from Mk3 to Mk4 taillights on a 2010-2015 caddy? Using VCP that is.
Thanks!
Roan’s Caddy
Post by Roan’s Caddy »
Clutch master cylinder replaced today.
Shes back baby! Image
Yayyzer
:D
STP
Post by STP »
Poffe wrote: Wed Jan 14, 2026 9:05 am Although, changing anything in the BCM coding seems to be a huge risk and when ever I read something about it there is always clear warnings.
You also need "vaghelper neXt" software to edit the hex bytes for the PQ35 B+ platform cecm, go find a website called www.binunlock.com, I just joined it and it's fantastic, free, and has these tools available. Get vaghelper and when you do a dump of the central electrics module 09 using VCP, vaghelper can modify the correct bytes to fix the tail lights. Also runs on windows xp. Then you write it back using VCP and the lights are working. I'm looking into doing the DRLs to led coding.
One warning, DO NOT touch byte 18 or hell will descend upon you. It is a hidden value showing only 00 and protected in PQ35 platforms and deep misery results from touching it. You won't need to touch it for what you want anyway. Get over to that forum and sign up, then get vaghelper. Post questions on what you are trying to do and you will get clear answers.
Poffe
Post by Poffe »
STP wrote: You also need "vaghelper neXt" software to edit the hex bytes for the PQ35 B+ platform cecm, go find a website called www.binunlock.com, I just joined it and it's fantastic, free, and has these tools available. Get vaghelper and when you do a dump of the central electrics module 09 using VCP, vaghelper can modify the correct bytes to fix the tail lights. Also runs on windows xp. Then you write it back using VCP and the lights are working. I'm looking into doing the DRLs to led coding.
Thanks for the tip!!
I found a video on YouTube explaining how to. It didn’t say anything on byte 18. But as you are saying, didn’t need to touch it at all.
Found binunlock as well yeasterday through a google search. Also found VAGHelper through another website and ended up using it from there.
This video was pretty helpful during the coding:
https://youtu.be/C4n2rsFfTxk?si=FWee-FPyd0Tl0BM8
Not the best pic, but at least I got it working properly!Image
Sent from my Nokia 3310
AshDowe
Post by AshDowe »
Hi all,
New here, got my caddy few weeks ago. It came with only one key and didn't have remote locking :(
Been messing around with universal lock kits and all sorts.
But today I managed to code the original CCM to accept a new remote key and it all works perfectly!
Now for electric windows
mirogo
Post by mirogo »
Sprayed my bumper as beginner with 2K spray cans :lol:
Flog_TSC
Post by Flog_TSC »
Fitted a new abs sensor to nsr done some insulation in the rear doors that’s it u till tomorrow
mirogo wrote: Fri Jan 16, 2026 8:53 pm Sprayed my bumper as beginner with 2K spray cans :lol:
Looks great
Poffe
Post by Poffe »
mirogo wrote:Sprayed my bumper as beginner with 2K spray cans :lol:
Yeah, I agree, it looks mint!
Ive thought about doing it to my van ever since I got it!
STP
Post by STP »
It looks really smooth finish, did you have to rub down the texture first? I'd like to do my bumpers body colour.
davoc220
Post by davoc220 »
Yesterday I ordered a set of rear spring poly bushes, purple 1s cause I couldn’t get the black 1s and got 2 tyres for the new alloys
