C Chis
Re: Let the build begin - Plushed/Bagged VR6
Post by C Chis »
Been a little quiet of late…. Just enjoying the van… however….
Made a start on making a couple of blanking plates for the barn door retainer holes
Prepped and painted them along with the reinforced strut plates for my barn door to tailgate conversion
Also fabricated the support (not primed yet) for between the outer cross member and the inner mounting for the tailgate hinges, still to cut in two and then to length and work out how thread them through the openings…
Mister_ShWa
Post by Mister_ShWa »
Looks fantastic, will have to find a bit of time and have a read from the beginning!
Hi C. Chis,
Just checking to see if you made any progress on your tailgate conversion. Did you make the strut brackets or is that something that can be got from VW?
C Chis
Post by C Chis »
Hi [mention]FishermansFriend [/mention]
No progress since last post, my daughter’s bought a cottage that’s turned into a full renovation… only downside is she’s 400 miles away and my mates garage has been pretty much fully booked when I’ve been free
The brackets are repair brackets from VW to replace the flimsy OEM ones that have a tendency to crack around the threaded part.
Part numbers are 2K0827435 and 2K0827436. They are available from OEMVW parts or from eBay (~£26)
Hoping to get it done in the next couple of weeks before I head back down for round 4 of house renovations…
Thanks for the info and part numbers. What is your thought on reinforcing for the struts, its the only thing putting me off. I've went through the parts diagrams a few times now and I can see the reinforced rear cross panel for the hinges but I cant see any part for strut reinforcement, so maybe there is none. Good luck with the renovations, hopefully all going according to plan.
C Chis
Post by C Chis »
The part numbers are for the strut plates, I’ve popped the left hand side one on with a magnet to give you an idea.
For the hinge mountings I traced the cut outs from a tailgate van, both the wiring and the hinge cutouts, just visible in the image below. I’ve fabricated a U shaped panel to weld into the hinge cut out to strengthen the rear roof member very similar to the actual reinforced roof member that VW used to sell. Still to cut it to make left and right hand brackets and then to size. The bracket might be overkill, however it seems the right thing to do and will also keep any rain out of hinge slot.
You might be able to find the cross member for a tailgate van, however, it will be a nightmare to install as the cross member is spot welded and bonded in.
