More wiring done, supplies now in place for lights, fans, diesel heater, USB sockets, fridge, and water pump. Diesel heater is through a 30A relay, USB, fridge, and pump are through 10A relays, lights and fans are direct through the switches as they draw less than an amp.
The "tight" looking wire running to the right is for the fridge, it'll sit more upwards when installed so won't be under tension.
Now I just need to find a way to mount the control panel, and I want to add some labels to each of the connectors.
