3.2 v6 Turbo DSG 4X4 Multi link Conversion
Poffe
Re: 3.2 v6 DSG conversion
Post by Poffe »
Pineapple1984 wrote:Image
Is it a CC stalk I’m spotting? I’m trying to figure out which stalks I need. I have got a SW with the exact buttons you have. Does it work with CC stalks?
Skickat från min iPhone med Tapatalk
Pineapple1984
Post by Pineapple1984 »
@Poffe, yes CC stalk will work it’s the MFD stalk on the opposite side you will need a blank switch. Then you can code j519 to multi function steering wheel. Then providing you’ve got the correct steering column ecu to support it. everything should come on line. If you haven’t got CC already installed your need to activate that too.
Poffe
Post by Poffe »
Thanks! I have CC and MFD on my stalks. Thought I had it all figured out a few days ago. But I continued reading and got confused again 😅
Poffe
Post by Poffe »
Also, must admit I’m really jealous on your instrument cluster!
Pineapple1984
Ha ha, you wouldn’t be jealous of the cost
Poffe
Post by Poffe »
Pineapple1984 wrote:Ha ha, you wouldn’t be jealous of the cost Image
Haha, I bet! But still triggers some “must have” feeling inside
Poffe
Post by Poffe »
When you chaanged Dashboard to the Touran one, did you aslo get a passenger aribag installed?
My caddy is missing an airbag and I think that is a damn shame for a car manufactured in 2014. Trying to figure out if it is worth refitting or even possible.
Pineapple1984
No I didn’t retro fit an airbag,I’ve not had any dealings with adding an airbag but I’m sure if you put something out on the board someone will have done something, I imagine an ecu upgrade or maybe just coding and wiring??
Poffe
Post by Poffe »
Maybe it is that simple. But probably not :lol:
Pineapple1984
Ahh, that’s better! All matching now
Pineapple1984
Bought some fabric from AS trim. Suede lined the headlining, shelf and both A pillars. Man that was a ball ache Image Image
Damo2k
Post by Damo2k »
That looks very tasty mate well done. makes world of difference
Damo2k
Post by Damo2k »
Where did u get your cluster from?
On my to do list
Pineapple1984
Timing chain day today! That was fun pulling it all apart again. ImageImage
Pineapple1984
