Dan's fishing van
DW2207
Re: Dan's fishing van
Post by DW2207 »
My led drivers arrived from a skoda dealership over in the Czech Republic.
Still can not believe how much cheaper these were to buy from there than purchasing over here, 250 euros delivered.
All fitted and now have a Image lite drl bar now and side light on the xenon headlights.
I'll make sure to double check part numbers going forward a bit better Image.
Not the best pics, bit there are loads of better ones on here of them fitted.ImageImage
DW2207
Post by DW2207 »
One of my vehicle ownership enjoyments is keeping them clean and tidy.
I do like the usual snowfoam wash, but in recent months I've been playing around with the rinseless wash system
This is something I will be definitely keep doing going forwards, especially if I have limited time or during the summer months.
Products I use for this are
P&S absolute rinseless wash
P&S beadmaker (used as a drying aid)
Microfiber wash mit
Single bucket with grit gaurd of absolute
5L pump sprayer
Various drying towels for body and wheels
Gtechniq tyre gel.
I've recently this summer gave the whole van a single stage machine polish with diy details gold standard polish, and coated with cquartz uk 3.0 ceramic coating.
Was looking to just remove the milky/hazy finish to 4 years of neglect. There are still some deeper scratches, but you do need a good quality light source to see them.
Clearcoat preservation is more important to me.
The wash process is now a breeze and joy to do.Image
Van is spotless Dan and VERY shinny. Hope your still enjoying your fishing.
Post by stu_b »
wait, there's something on the drivers door, a bug or something
hahaha
looking mint
DW2207
Post by DW2207 »
cheers lads,
Hi Wayne, yes mate still out fishing. Dropped on to my winter water now mate, hope your still wetting a line buddy .
Thanks stu, the bug didn't last long mate
Post by stu_b »
hahahaaa no, its a big bug
aka your reflection in the shiny paint work !!!
DW2207
Post by DW2207 »
You f@xxer stu
Projectil_CZ
Post by Projectil_CZ »
Hello
This is best. Really
DW2207
Post by DW2207 »
Hi, thank you for the comment mate
hef355
Post by hef355 »
Great work Dan mate!
Meticulous in all you do fair play mate and always modest
DW2207
Post by DW2207 »
Thank you heff, blimey that's a nice compliment mate. Always appreciated buddy
Philush
Post by Philush »
That's a straight and clean caddy wow,
Sent from my SM-A236B using Tapatalk
Reason: Quote removed
DW2207
Post by DW2207 »
Thank you.
Another update to the caddy.
I bought a reversing camera kit from vagtec, and with the weather nice and dry Decided to get it fitted.
The kit came nicely packaged with a sticky label to show where to terminate the open cable ends.
Wiring loom was probably the longest part to get into place.
Required one half of it to follow the main rear pdc/rear tail light loom to the front cab, and the other half to go down the left rear quarter were you will need to get your earth from the stud, and splice onto the reverse tail light trigger wire.
At the cab end, it was a case of routing the red 12v power feed cable to the interior fusebox under steering wheel.
Now this will need to be crimped with a junior power crimp so that you can push it into the correct fuse way.
For whatever reason, the instructions recommended fuse18 on the C part.
This is incorrect as the caddys have no ignition feed busbar link over to this fuse way. We'll at least not on my model caddy.
The available one is fuse sc23.
You will need to slide the purple tab out in order to fit the crimped terminal.
I then fitted a 5amp fuse for this circuit.
The other part of the harness needs to be routed to the headunit.
Once there, you will need to remove the headunit and unplug the quadlock plug.
Remove the blue 12pin plug and lift up the 2 tabs to allow the 2 crimped cables to be inserted in.
White one goes to pin6 and black one to pin12.
Then to code I used obdeleven.
Not much information on obdelevens forum on this, so I scrolled through the modules on my caddy that I thought would be applicable.
I have screenshot these from my obdeleven.
Will need to go into
Central electrics
Parking assistance
Multimedia
OxCaddy
Post by OxCaddy »
That’s very nice!
Nice work Dan and its a good field of view.
