Brycieboys Blue Wagon 20"s are on
Klenk
Re: Brycieboys Blue Wagon 2/1/12 rear seats modded
Liking that matey, looks spot on.
- DADDY
Class work BB bud, top self. Id say Docs not to far of the truth either
- brycieboy
Cheers bud least i can say mine was the first
dozz
Great job on the seats
MoNkEyBoY
Brycieboy, whats the chances of meeting up after the 12th Jan to get some info off you? I'm in Fife too but wont be back until the 12th, also have you decided what painter your going to use yet ???
- brycieboy
Aye no prob dude gimme a shout when your around
keith
quality job there. how did you mount the seat belts to the sides of the van?
- brycieboy
for the top mount i welded a nut onto a 5mm thick 50mmx50mm plate, drilled a hole in the van and fed the plate behind the panel, once i had the seatbelt bolted i drilled another small hole so i could put a pop rivet to keep it in place if i need to remove the seat belts, the inertia reel bit fits into a slot already on the van and is just a case of putting a bolt through and the bottom is a 50mm steel angle bolted to the holes in the floor that took the load rings and a hole drilled to suit the belt mount then bolted.
sure ive got pics on this thread somewhere
dubdad
- PhotoPete
Those rear seats are fantastic
Makes my rear beach seat look even more rubbish.
Great work on the fitting of them.
Pete
Pete
Splitpin
Looks great, I was going to go down that route but I needed 3 full seatbelts in the back.
rob_dbn
loving this caddy ....Rocco seats are the bomb ...great work !!!!! ...
Do the Rocco seats not need a lock pin to hold the rears up ???
Adi Boy
great work mate looking very very nice
Ollie370
What's the deal with insurance and registration putting seats in the back? I guess you have to tell the DVLA that you have more seats! This could change the tax bracket too?
Taddy R Project - Engine running
viewtopic.php?f=13&t=19895
Splitpin
I have done a few rear seats and I just change it to MPV and 5 seater, never changed the taxation. It's classed as a crew van.
