The caddy project
big harty
Re: The caddy project
Got the same seats with touran bases in my 2007 tdi caddy. Morally comfy and very supportive. And I'm 6ft4 and 17 stone. Lol. I may have a Kenwood touch screen sat nav DVD Bluetooth coming up for sale and a complete touran bumper
W3 HTR
hi mate a just put a set of leather s line seats in mine and just drilled new holes in old subframes and nut and bolted them then put them in together. just an idea for u mate. was dead easy and saves gettin sumframes.
big harty
Doing it that way sounds good but do you find you sit too low in vehicle. Mind you I'm 6 ft 4. Lol.
- vinnie
Well i'm visiting Aladin Cave 2moro to pick up some rear seats!!vinnie wrote: I've not been yet but he did deliver me a centre console when he was last up in Scotland! Top bloke and the centre console is the best bit i've fitted to mine so far!
Your caddy is coming along nicely mate!!
- hulk
evans1089
Looking good there mate! Similar plans for mine
Clubster
Cheers guys
Finally after waiting to get the right size spline socket
I sourced some touran bases last week and set about fitting today - I'm missing one of the bolts for the seats which fit into H frame so if anyone has one laying around could they give me a shout as the standard caddy seat bolts aren't the right size.
Can't believe how much better the are than the standard caddy ones so if anyone's considering- do it!
I got the back seats with these, they were in a bit of a mess so now cleaned and ready to be stripped down as I need to use the fabric..
- Wardy1
Fitted my bases yesterday and ended up down the local vw spares buying new bolts , it broke the bank @86p each ( part number . N909 369 01 )
And your right , it's totally different on those bases
Lovely jubbly
Lovely jubbly
Metallic Black 1.9 Powder coated original r32 alloysTouran Front SeatsRear wiper Removedtinted rear glass & solid van guard window grills
And vmaxx coilovers
.........soooo much i want to do
Clubster
Thanks for the details
Clubster
Bit of a session yesterday.....
Time to weld this in
Made these cutting ten pieces with 10mm holes drilled in, these were placed under van floor to help bolt hold brackets down
Then as I've never welded before I passed this bit over to a friend
Slightly worrying seeing smoke coming from wheel arches
Everything welded up and sound deadening fitted..
Seat belts in but just need to collect some bolts from vw for the top belt mounts and sort the lower belt mounting bolts
Seats in, they match quite well to the GT front ones
- Gibbo185
Hi sorry to but in on your page but call rus on 0797020965233 at sirus ref lower bolts as need a sleeve to stop floor crushing he sold me a set bolts and need a 16mm hole bore
Tsi 2.0 ea888 dsg mk4 maxi
Clubster
Thanks, are you talking about the lower seatbelt mount points?? I'm planning on using a 12mm bolt with nylon nut and spacer on top and bolt/spacer underneath.Gibbo185 wrote:Hi sorry to but in on your page but call rus on 0797020965233 at sirus ref lower bolts as need a sleeve to stop floor crushing he sold me a set bolts and need a 16mm hole bore
- Gibbo185
By all mean give me a call on 07788946378 can try help explain
Clubster
Wheel shopping.. I hate choosing wheels so what ones do you reckon???
Option 1
These I love but they've been done
Option 2
18" wheels of eos
Option 3
19" merc amg rep wheels
Option 4
19" rotifakes nues
Option 5
Tarmacs
Option 6
19" Helios rep wheels
Option 7
19" Rocco's reps
Option 1
Option 2
18" wheels of eos
Option 3
Option 4
19" rotifakes nues
Option 5
Tarmacs
Option 6
Option 7
19" Rocco's reps
- Adam@PureDents
The Tarmacs look good but you can't go wrong with some Helios
