side rail cover kit
Matt@Reflex
Re: side rail cover kit
Post by Matt@Reflex »
tommyzooom wrote:Do you think these would have all the sizes required for most jobs on the van? removing seats etc
http://www.amazon.co.uk/Draper-12769-Pi ... 456&sr=8-1
Available for £3.52 delivered :D
I think you might need a 4 and that set only goes down to 6.
I'm not at work today but i can check tomorrow.
They are worth having though. They use them a lot now. Check out all your door catches and latches.
de oude gek
Post by de oude gek »
Got the rail fitted today, spline 5 made it a breeze!
Drilling the hole and changing the clip is for lunchbreak tomorrow.
Frank
Stucat87
Post by Stucat87 »
Did folk go for the above sizes for hole 50x50 or did folk use the fittings on the fools link below it. As I found 50 mil was to high as it has a ridge on outside which doesn't let the bracket sit flat against van. 34 seems more like it.
