Liams Mk4
- Liam
Re: My Mk4 reflex silver
ive good carpet coming today for the floor its black and hardwearing i might also see can i get rubber or lino to go over it for when i have the bikes in the back will see what the shop has when i get there
Build thread here
Build thread here
- Liam
Busy day today plylined the van and carpeted it
ordered my foglights so hopefully they will be here tomorrow also
man im broke
Build thread here
Build thread here
- Ddraeg
- Ddraeg
Just read your reply in Interior Mods. Think I understand now! lol Thanks!
- Liam
hey pal they are just expanding trim clips easy to remove and hold the panels firmly in placeDdraeg wrote:Just read your reply in Interior Mods. Think I understand now! lol Thanks!
Build thread here
Build thread here
- Ddraeg
Cheers matey! It was the stopper on the drill that threw me! Didn't understand what was going on lol! Great idea, I might do the same!
- Liam
yea its definitely needed in case the drill slips or you will damage the outer panel
if you dont have a stopper like mine you can make one by drilling a hole in a piece of timber and slipping it across the drillbit so only 8mm or so of the drill bit can poke out
the rear panels have about 15mm of space between the support panel and outer skin whilst the front panels slide door etc only have 10mm or so
Build thread here
Build thread here
- Liam
So i got the rear ply floor finished today
its 9mm plywood and its now sandwiched with foil backed insulation on the underside and 4mm carpet on the outside finished off with an alloy trim strip at the side door and then where the carpet meets the rear plastic at the doors i ran a bead of black tech 7 adhesive along the joint to prevent the possibility of dirt getting in
Build thread here
Build thread here
Caddy63-Adrian
Where did you get the floor carpet from? It looks the same as what my panels are done with and cannot for the life of me find it anywhere!
- Liam
local carpet store he has tonnes of it
Build thread here
Build thread here
gkindley
Awesome posts - this is exactly the finish I am thinking of doing in mine. Hope you don't mind me asking.
Where did you get the expanding plastic clips from?
What is the foam based foil back insulation? Does it sound deaden well?
- Liam
no problem at all if its of use to someone thats great
the plastic clips are just trim clips available from halfords or ebay or amazon i got mine in halfords because its beside me
the insulation is foil backed insulation for under laminate flooring its better than the cheap white stuff and is about 7mm thick it will have some sound deadening properties and it prevents the sheet of ply from vibrating off the floor of the van also
Build thread here
Build thread here
- Liam
managed to get the fogs fitted today
see my post in how to section if interested in seeing it
Build thread here
Build thread here
- Liam
Serious light out of the new fogs love them
Build thread here
Build thread here
Glen G
Good job so far bud looking forward to seeing more
