Engine cover difference
clewis1878
Re: Engine cover difference
Post by clewis1878 »
@Katiecaddy
Hi Katie, did you find any further info for your engine cover? I've got a 2015 mk4 caddy maxi with the 1.6 tdi CAYD engine. Wondering if you had any joy on the part number?
Thanks Ciaran
Omanvanman
Post by Omanvanman »
I have a 65 plate mk4 maxi 1.6TDI and I’m also after the part numbers that fit for the engine cover and bottom tray? Thanks
VW Caddy Maxi MK4 1.6 102 - Member of the ex British Gas fleet van society :D
DaniPC
Post by DaniPC »
I like it, is there acoustic improvement by installing engine cover?
Best regards,
DaniPC
DaniPC
ex 1983 Renault 5 Copa (Alpine Turbo) (110 hp)
ex 1990 Opel Vectra GT (112 hp)
ex 1999 Seat Toledo TDI (90 hp)
ex 2005 Seat Leon FR TDI (150 hp)
ex 2005 Seat Leon Cupra R (225 hp, TLR Stage 1+, 268 hp)
ex 2013 Volkswagen Caddy TDI (102 hp, TLR Stage 1+, 135 hp aprox.)
2013 Volkswagen Caddy 30 edition TDI DSG (170 hp)
Gianfry
Post by Gianfry »
Does anyone know if there is a cover also for petrol version?
Caddy Maxi 1.4 TGI - 2017
Expelec
Post by Expelec »
DaniPC wrote: ↑Fri Jan 29, 2021 9:44 am I like it, is there acoustic improvement by installing engine cover?
Best regards,
DaniPC
Just installed mine this afternoon. Its a bit better. but the difference between then and now is not like that between night and day.
It will just improve it.
Gianfry
Post by Gianfry »
Dave2022
Post by Dave2022 »
EX_gas-Cop wrote: ↑Mon Jan 13, 2020 7:56 pm Image
Is your engine ad blue? Does it even matter? Ha I have a mk4 1.6 with ad blue and totally not sure if it matters. Loads of those Seat covers you’ve mentioned but none specifically for caddy for sale
Reason: removed part of quote
Poffe
Post by Poffe »
anoneamus wrote: ↑Wed Jan 08, 2020 10:13 am These are the part numbers I used:
1x 03L103925R - cover for intake manifold (VW, TDI)
2x 03L103164 - Ball head bolt
1x 03L133287 - O-ring
Fitted my new(used) engine cover today! Like a glove!
Bought Ball head bolt and O-ring new from local VW-dealer with part numbers as above. Thank you for this!
fuzzydunlop
Post by fuzzydunlop »
I’ve got the cover and the ball-head posts are on their way. What do you need the O-ring for?
Poffe
Post by Poffe »
O-Ring is for mounting around oil cap. If you spill some oil when filling in the oil cap it will stay up on the small surface around the oil cap and not drip down on engine block, cables and what not.
fuzzydunlop
Thank you. Good to know. Especially having just cleaned the top of the engine!
Poffe
Post by Poffe »
Now that I have secured that the oil won’t drop I might just give my engine a good scrub
Skickat från min iPhone med Tapatalk
Norcot
Post by Norcot »
Check the engine code / type my 2015 1.6 is a CAYD, I bought a Seat cover for CAY 1.6 tdi engine and like others it’s perfect fit. Just need to buy two screw in ball / studs which screw in and the cover clips onto
