2008 Ravenna blue caddy build
Billy.2kcaddy
Re: 2008 Ravenna blue caddy build
Post by Billy.2kcaddy »
Nothing better than seeing that power light on an amp Image🫣Image
Sent from my SM-S908B using Tapatalk
Billy.2kcaddy
Speakers complete, put a little bit of sound deadening in just because It was open.
Sub box is done for now until I get round to sorting the fabric for the back, then I'll tidy it all up.
I'm still waiting on the tweeter adapters and a couple of rca Ys for the 4 Channel Amp, but I'm very impressed with just one of these hertz components Image amazing quality.ImageImageImageImageImage
Billy.2kcaddy
Tweeter adapters turned up (got of eBay), not the best fit, but just re drilled the holes.
90-degree elbow cut down and put on for the intake, which I've been meaning to do for a while now.
Exhaust turned up also so I can get it all booked in for a map !!ImageImageImageImageImage
Billy.2kcaddy
It's been a while since I updated this build. Van has mostly been at pd parts, getting a check over and exhaust fitted, and a map.
I'm hoping to get it back next week and commence the interior change. My kitchen has basically turned into a touran Image.
Tried some dark grey plastic paint on a piece of plastic in the back, and it's too grey for my liking, so I need my van back to match that so the front is blended in better.
Also received my gaiters in gti blue from retro retrims (taken 2 weeks) to come, which is what they specify but they look really good quality.
Billy.2kcaddy
Caddys back and moted!
Bit of tlc on the new exhaust (welding up the joiner)
Hopefully, start the fun stuff soon ImageImage
Billy.2kcaddy
Carpets semi fitted, changed my crossovers as I wasn't a massive fan of the cheap other ones that came with the speakers.
Armrest is done too, but I forgot to take a photo Image
Just need some time to spray all the bottom plastics dark grey and put them back in, finish the gear gaiter as I couldn't find my staple gun. ImageImageImageImage
Brutus1989
Post by Brutus1989 »
What sound proofing did you use and how much did you buy?
Van is looking well! 👍🏼
Billy.2kcaddy
Brutus1989 wrote:What sound proofing did you use and how much did you buy?
Van is looking well! Image
Thanks, mate.
I used some quite expensive stuff from vandilised called dead mat pro, I think I ordered about 120 sheets ish as they are only small, but the quality is unreal.
Billy.2kcaddy
So sorted the gear gaiter tonight, and it's a perfect fit!
Also, a shot of the touran centre console, which I'm hoping to get the matching armest cover. Once I've completed the interior plastics in dark anthracite.Image
Billy.2kcaddy
All lower plastics painted, the difference is so much better.
I ended up going with the pro xl smoke grey as it was the nearest match to the dash. All bits were fine scotched and washed, then given 3 coats of paint.ImageImageImageImage
Billy.2kcaddy
Plastics are all fitted, look a lot better, and much darker, not a perfect match, but I'm happy enough.
Need to get some touran door cards and new seats and paint the top plastics and cover the headliner for the interior.Image
Brutus1989
Looks a good match tbh!
May see if that spray is on Amazon!
Billy.2kcaddy
Brutus1989 wrote:Looks a good match tbh!
I tried the dark grey, which I thought was really grey (funny that).
It's more of a like black/anthracite which I've been through the colours to match a panel with nothing coming up close except the smoke grey!
Brutus1989
Does look really good mate, I need to spray all mine so glad I stumbled across your page!
Billy.2kcaddy
Brutus1989 wrote:Does look really good mate, I need to spray all mine so glad I stumbled across your page!
No worries, mate, it's not too bad. I used about 2 and a bit cans for the bottom pieces, so I reckon you'll need about 5 ish.
