Ah ok. It's the only sensor that often shows no fault code for no signal, as there's no signal with the ignition before you start it since the engine is not moving yet, so they suppress the error or it would show up every time you went to start a car or van.
Hard one to find except by testing or substitution.
Sudden dip in power when cruising, drives fine other than that
STP
Re: Sudden dip in power when cruising, drives fine other than that
