Micro Camper Daily Driver Build
jakemcc97
Re: Micro Camper Daily Driver Build
Post by jakemcc97 »
Nice work! I'm just starting out on a camper build, loads of ideas to draw inspiration from here. Hope you don't mind if I nick your idea of using the tie down points to latch the furniture in.
How do you find daily driving a camper?
Jake's Caddy Camper Build
Silver 2017 2.0 TDI Highline
PJD
Post by PJD »
jakemcc97 wrote: ↑Sat Aug 30, 2025 11:20 pm Nice work! I'm just starting out on a camper build, loads of ideas to draw inspiration from here. Hope you don't mind if I nick your idea of using the tie down points to latch the furniture in.
I got inspiration from a previous van we had from which used the over-centre catches and J bolts in the rails they fitted. So go for it.
As a daily driver the Caddy is pretty good. The conversion makes a bit of noise that I'm yet to chase down but don't notice the weight.
Flog_TSC
Post by Flog_TSC »
Just read through all this great build
PJD
Post by PJD »
Thank you
jakemcc97
Post by jakemcc97 »
Just had another flick through your thread - do you mind sharing where you got your windows done? Do you ever find the need for a second slider or are you happy with one sliding and one fixed?
Cheers!
PJD
Post by PJD »
jakemcc97 wrote: ↑Sun Sep 14, 2025 11:50 pm Just had another flick through your thread - do you mind sharing where you got your windows done? Do you ever find the need for a second slider or are you happy with one sliding and one fixed?
Cheers!
The windows come from Campervan Glass. I got them fitted by Berkshire Campers in Hurst near Twyford, Reading.
The one slider seems perfect. It's not very sophisticated with a big recess on the outside but it functions fine and has effective drip channels that drains water.
It provides some ventilation without needing the door open and I can open the other door or crack a window open for a cross breeze.
Good level of tint. You can't see inside but there is a good view from inside
I would probably choose to do the same again.
jakemcc97
Post by jakemcc97 »
PJD wrote: ↑Mon Sep 15, 2025 4:52 pm The windows come from Campervan Glass. I got them fitted by Berkshire Campers in Hurst near Twyford, Reading.
Great, thanks for the advice! Been tossing up whether to go with an aftermarket slider or try and get hold of an OEM one, but it's encouraging that you think the aftermarket one is a decent piece of kit.
PJD
Post by PJD »
This is the original power station I bought to fit behind the passenger seat. Bluetti has bought a new one out the Elite 100 V2 this has a bit more capacity, better display and quicker charging. Crucially it fits the same space!
The new power station has meant that my fridge will run for over 3 days now so enough capacity for a weekend away but still needed to be removed to be charged. So decided to get Bluetti's Charger 1, which is a universal B2B charger for power stations.
The B2B comes with a long run of cables for connecting to the main battery. There is a loom going through the firewall behind the battery. It has a strange kind of twisted grommet that I fed the cables though.
This is the Charger 1, fitted to a panel I made up to sit within the Life carpets I fitted.
This is the fuse panel for the 12v system. Strictly speaking I don't need it because the power station has circuits to protect the outputs, but it provides a first line of defense.
The whole setup
Excess cables tuck behind
Setup and running. Power bank should fully charge from flat in less than two hours while driving.
It's essentially the same as a leisure battery setup with an inverter, and B2B and about the same cost.
Wiring was put in place for electric hook up and a solar panel at a much earlier stage in the build should I ever feel the need to add these in the future.
There are some benefits. I've already swapped out the power station once to increase capacity, I have high powered USB C's and an app that controls both units and gives me usage data.
Flog_TSC
Post by Flog_TSC »
PJD wrote:Image
The whole setup
Makes me want one of these now haha I’ll only do 2 days at a time in mine I reckon but makes it just that bit more comfy I reckon great post by the way
Post by stu_b »
VERY very nice PJD
this suits your needs n set up to a T
Nice work
Those cables look heavy duty
PJD
Post by PJD »
Yes impressed with the cables. Reassuringly thick but super flexible. I worked out that they deliver just over 40 amps.
MarkTrump
Post by MarkTrump »
That sounds great. The tint and ventilation seem perfect and it’s good the slider works well and keeps water out.
Minty_Gee
Post by Minty_Gee »
Loving this build. Keep up the work!
