New bumper from GTi Kris, painted, wrapped and fitted.
Same as the previous one but the old one had terrible fitment.
Super happy with the fitment of this one. Absolutely spot on.
Cherry on the cake is the new hybrid honeycomb grill (also from Kris) but I'll be honest needed ALOT of work until I was happy with it.
Bodyshop did a great job with it, smooth as glass now.
Completely changes the front end and adds a touch more "unique-ness" to the van, while matching the honeycomb in the bumper ImageImageImageImageImage
Hell-a-gorgeous !!!
8)
Nice one Gazza
mac12
Post by mac12 »
Brake job. Rear pads and rotors.
Right hand side caliper was completely spent. Boot was stuck to the piston and tore upon rewinding. Such a shame as everything had been going smooth up to that point. Even got the super seized caliper bracket bolts out. Can't be arsed doing a piston repair, so might as well just replace the entire thing. I'm having a hard time sorting out the PR-codes and thus finding the correct caliper. If you have any ideas which PR code is fitting for my caddy (2012, 75kW / 102bhp, 1.6tdi), please let me know.
I've put a 272x10mm rotor on it, and matched it with the appropriate pads (2K5698451) which are identical to the old ones.
These point me to the 1ZA pr code.
BlueJay
Post by BlueJay »
I didn’t do it but a garage did. 2 new suspension springs.
This van costs me a fortune!
New brakes in today ImageImage
Jase14
Post by Jase14 »
What size discs are those Gazza ? What did you do with the old bumper?
the67al
Post by the67al »
New brembo discs all round plus mintex pads and 4 new tyres in preparation for mot
Sat around for 5+ hours waiting for a tow truck
Luckily parked in the shade.
Engine cranks, but misfires and stops !
Whiteline arb and bilstein b8s on the rear... Same here to get through MOT!
@petrev ahhh gutted for ya mate any ideas what's wrong yet?
philsparky
Post by philsparky »
fitted a rear lock/unlock switch
2017 Caddy Trendline 2.0TDI 102ps, Reflex Silver
gazza31112 wrote: Thu Jul 10, 2025 9:11 pm @petrev ahhh gutted for ya mate any ideas what's wrong yet?
Not really sure ??
After 6 hours sitting around (I tried it every hour just incase) I tried it one last time and ... It started !??!
Couple of odd things still wrong - Fuel gauge read empty (0 miles range) but after a 12 mile drive home it said it was in the red and 25 miles range - From memory of where the gauge should be it is still reading low !
Also strangely, the right powered window now doesn't do auto up/down, and doesn't close on the key lock button press+hold.
? Fuel sender issues ?
No idea really :?:
philsparky wrote: Thu Jul 10, 2025 10:05 pm Image
Nice one Phil
Have to post more info on what you did (exactly).
Nice work.
@Jase14 340mm mate, and honestly the old bumper went in the skip! It was so terribly bodged up by the guy who I asked to "fix" it.. it would of been unfair to sell or even give it away in that state
philsparky
petrev wrote: Nice one Phil
Nice work.
switch: https://uk.rs-online.com/web/p/rocker-switches/9131926
switch cover: https://uk.rs-online.com/web/p/rocker-s ... rs/9132070
I had the resistor in stock but im pretty sure you can find them easily.
connect a wire to the brown/green wire behind the factory switch in the door, run it to the rear with another wire grounded to one of the dashboard mounting points behind the drivers end panel, connect to the switch and voila!
(i can’t remember which way around the ground and ground w/resistor go on the switch, if the unlock button locks it just swap them around)
if you use the switch i used then pin 2 connects to the brown/green then pins 1 & 4 are the ground/ ground w/resistor.
