rns 510 or rns 510 with dab
carp69
Re: rns 510 or rns 510 with dab
hi did you undo the plug then feed the wires if so can you tell me how to undo the plug cheers
smeg
how does the mirror come apart
- phanson
The hard way - as far as I know you have to pop the mirror out!
Many breakages later the technique is improving.
smeg
sussed it but no dab aerial
wheres best place to get a vw one
gilly
If your not going for the factory look,why not fit a DAB shark fin/stubby arial on the the roof????
- dan@biali
That's what I've got as there's no room inside the Touran mirrors for all the aerials. I think it's from a Tiguan part number 1K0035501J. You will also need the stubby aerial for it. Mine has fm, phone, gps, and dab so not cheap.
smeg
wanted the factory look need to get dab in the mirror
gram67
Is it possible to fit n/s mirror dab aerial in a 2008 Caddy?
Thanks in advance
Thanks in advance
- Banditbarron
- Sales Caporegime
carp69
fitted the rns 510 whith dab and oem aerial in mirror and its the nuts
the long one
Question - will this work (dab only) with 2K5 035 525 J or do I need to get 2K0 035 525 K (only going to use the dab part)
Thanks in advance
Thanks in advance
Mike89
Ok. So, if I buy and rcd 310 with dab and fit it to my 2011 caddy, what else do I need to purchase? The loom to connect the radio to the mirror aerial?
A DAB antenna if you don't already have one.
