My Blackberry Caddy
Lovecaddys
Re: My Blackberry Caddy
Post by Lovecaddys »
Hi were are the bulkhead covers from? Thanks
Barbel330
Post by Barbel330 »
Contact Tommyzoom on here, or he sells them on eBay.
Instagram: @y_5cuf
Barbel330
Post by Barbel330 »
New front splitter fitted, lowered the rear one notch and gave it a wash in the sunshine.
Instagram: @y_5cuf
Saxx
Post by Saxx »
Mate credit where it's due. That's looks love the colour of your van and all the subtle mods too. I didn't realise that 8.5 wheels would be catching the sliding door. I have the maxi but same shape, wondering if i will have a problem with 8.5 too
Barbel330
Post by Barbel330 »
Thanks. It only touched the ply lining so I've removed it from the sliding door now and it's fine. The tyres have rubbed a hole through the arch liner on the inside at the back of the rears on both sides :roll: so I've removed those now too until I can work out a permanent solution.
Instagram: @y_5cuf
Amelia
Post by Amelia »
What is c5?
Barbel330
Post by Barbel330 »
It's a wheel sealant from Gtechniq. It stops dirt, brake dust and basically any road grime from sticking to the surface which protects them and makes washing them a breeze. I've done all my windows with the glass sealant too which makes water run straight off with the added benefit of reducing the amount of ice build up on the screen. Good stuff.
Instagram: @y_5cuf
Amelia
Post by Amelia »
I'm likein the sound of that it doesn't look like a big enough bottle to do four wheels how long does it last where best place to buy many thanks
Barbel330
Post by Barbel330 »
It only took half of that small bottle to do the whole set of wheels inside and out actually. I thought the same thing when I saw it. It's easy to apply, just wipe on with the supplied cotton pads and buff off with a microfibres cloth. It's supposed to work for a year or so I think? There's a short video about it if you google it. I buy all of my cleaning/detailing products from Slims detailing, always had great service from those guys.
Instagram: @y_5cuf
Saxx
Post by Saxx »
Barbel330 wrote:Thanks. It only touched the ply lining so I've removed it from the sliding door now and it's fine. The tyres have rubbed a hole through the arch liner on the inside at the back of the rears on both sides :roll: so I've removed those now too until I can work out a permanent solution.
What about if you just raise the suspension a little?
Barbel330
Post by Barbel330 »
Saxx wrote:What about if you just raise the suspension a little?
:shock: That'd be far too easy, I want it sitting lower than it is rather than higher :D
Instagram: @y_5cuf
The Chiller
Post by The Chiller »
Where did you get the front splitter from please ?
Barbel330
Post by Barbel330 »
The Chiller wrote:Where did you get the front splitter from please ?
Triple R composites mate.
Instagram: @y_5cuf
Barbel330
Post by Barbel330 »
Been ticking over doing all the little details on the van recently.
Made some solid bulkhead covers with a removable panel on the passengers side so I can fit my fishing rods through the hole.
Instagram: @y_5cuf
Barbel330
Post by Barbel330 »
Bought some secondhand Touran mouldings off here and fitted them. It's a very time consuming job removing all the old tape and glue from the old mouldings but you have to do it properly before painting.
A real bastard of a job getting this stuff off the van after removing the old mouldings.
Got there in the end though
Instagram: @y_5cuf
