Brooneye's build
brooneye
Re: Brooneye's build
Post by brooneye »
I use a body shop just around the corner from where I work. I can't fault there work and pretty reasonable too
brooneye
Brooneye's build
Post by brooneye »
This how far I got last nightImage
Will try to get a bit more done tonight
Bigrace
Post by Bigrace »
I'll have to call in and have a look sometime. Looks way better in black
Sent from my HTC One_M8 using Tapatalk
brooneye
Post by brooneye »
Aye your more than welcome mate. I does look so much better in black and its pushing me to try and get the interior done as soon as possible but times a major factor
brooneye
Post by brooneye »
This morning I have been and collected the parts for electric window conversion (hope I have everything), bonnet insulation, engine cover and black touran carpet. Need to go to vw for the bits to fit the engine cover. Hopefully will get them all fitted over the next few weeks
tovtm
Post by tovtm »
Like what you've done so far. How does the head liner come down? Are all the fixings obvious to take the plastic tray down first to get to it? Thanks
brooneye
Post by brooneye »
Pretty easy. You need to unclip the top plastic on the seat belt, remove the belt with the screw, then pop the screw cover at the top of the pillar plastic remove this screw ( both sides) remove handles by exposing screws (both sides), remove the 3 screws on both sun visors and finally take interior light lens off to reveal 4 screws and the tray should drop.
brooneye
Post by brooneye »
Been to vw to pick up the parts for fitting an engine cover and while I was there got a price for a barn door spoiler. Is £150 the right price? Don't want to order one of I'm getting ripped off. Also I'm fancying changing my front bumper from thisImage
To thisImage
As I fancy fog lights and like the look of this bumper. If I did is there anything else I would need from the touran in order to get the fogs to work? From reading I understand they will need coding
brooneye
Post by brooneye »
Apologies in advance but I can't seem to find a how to. Bit of a scratch my head moment as I said I got all the bits to fit my engine cover. I worked out where to put 1 ball joint (bottom left of engine as you look at it) can't seem to work out where the second one goes (on cover bottom right but there does not seem to be anywhere on that side) and also does the rubber collar just sit around the oil cap
brooneye
Post by brooneye »
Picked these up a couple of days ago and thanks to a little help from Gresley will hopefully have them fitted soon
brooneye
Post by brooneye »
Had a bit of spare time at lunch so decided to fit my engine cover that I've had for a while and also the sound deadening for under the bonnetImageImage
And tomorrow's job will be to fit the roof rails I picked up at the weekend
brooneye
Post by brooneye »
In between rain showers tonight I managed to fit my roof railsImage
Totally changed how the van looks
brooneye
Post by brooneye »
Got finished work early so i decided to strip the grey interior and fit the black touran carpet I picked up last month.
Phase one
Old and new
Fronts
Also ran cables for install for when I get round to it
Back
Also after a bit of help on how to remove the bonnet release handle on the drivers side so I can get the plastic off. Will try to change the handbrake over and put the armrest in when I have a bit more time
Looking good, nice progress.
I'm 99% sure there's a how to on taking off the bonnet release lever.
brooneye
Post by brooneye »
Cheers Doc I had a quick search but will look into it
