Does yours have an extended foot rest on the left? I would’ve thought the accelerator pedal would be the same on the automatics with just the brake pedal coming down from above the floor/matJD's Caddy Build
- JD2k
Re: JD's Caddy Build
No worries
- JD2k
JD's Caddy Build
Van-X glove box check before fitting.. I need to pick up a rivet gun from work! Or has anyone used a different method/screw to fit?
Read up that the latch is a bit flimsy on these so I’ll remember to be delicate when opening
Craig2681
love the van mate do you know if the glove box from the tourans fit
- JD2k
Thanks mate
I don’t think a touran one is a straight fit unless you’ve swapped out the whole dash for a touran dash which would come with the glove box lid
- JD2k
Swapped out the old for a new dash storage compartment with lid and bonnet insulation today. Both super easy to fit.
- Golfchick
Have you noticed a change in engine volume since fitting the bonnet insulation?
- JD2k
It is slightly quieter while inside the van but not a drastic change in the noise level. I searched on the forum to see if other people found a change with the insulation and a few had noticed it was quieter.
- JD2k
Got a nice little collection of parts ready to fit.. just need some time to fit them all
Next on the list...
Paint inside trim & over head shelf + sound deaden cab roof
Dye head liner
VW Caddy Life sun visors with mirrors
Reverse Camera
Passat W8 Interior Light
Auto Headlight Light with Sensor Switch
R-Line foot rest
Golf R MK7 Gear Stick
Leather Handbrake cover
Rear VW badge painted
Side Rail Cover
Caddy 4 rear tinted lights
Caddy 4 side repeaters
Fit and connect touran center console rear vent panel & wire up 12V socket
12v Socket/Switch/voltmeter panel
6 x Led spotlights
White/Blue Led strip lights with custom headlining
LED light adapters for standard interior lights
Dash Camera front + rear
Touran door cards re-trimmed + new switches fitted + switch surrounds and handles painted
Electric Window Conversion using Touran Motors & Control Units
Head unit/heater control surround painted
Rear Spoiler
pioneer front door speaker upgrade
Internal barn door handle
Upgraded heated seats control panel + connect heated seats
Caddy Life MK4 mirrors
Future plans:
Tinted third brake light
Painted Caddy "Edition 30" side strips
MFSW
Remap
Custom front bumper
Custom rear bumper
Side skirts
Full body wrap
Wheel Refurb
Next on the list...
Dye head liner
Reverse Camera
R-Line foot rest
Side Rail Cover
6 x Led spotlights
Rear Spoiler
Future plans:
MFSW
Remap
Custom front bumper
Custom rear bumper
Side skirts
Full body wrap
Wheel Refurb
- Caddyluv
Soon adds up don’t it.
- JD2k
After a long wait these finally arrived from eBay.. Need to figure out how to connect the aux port as it’s got an input for a RCD310 cable.. The USB port also seems to disconnect my apple car play connection after a minute or so but there’s still power.. So a little tweaking to do but at least they look better than blanks
- Whitey
Great progress mate. You’re flying through with the mods
Might be able to help on the CarPlay front. How did you connect originally to the head unit?
- JD2k
JD's Caddy Build
Thanks mateWhitey wrote:Great progress mate. You’re flying through with the mods
got a box full of parts waiting to be fitted
The head unit (Pioneer SPH-DA120) came with two USB input cables that plug into the rear as below.. I then got an adaptor usb cable to plug into the usb flip button and plugged that into the female head unit cable.. carplay worked fine when plugged directly into the female socket from the head unit so there must be some cut off in the switch or adapter cable. I might remove the back of the flip button and directly mount the head unit cable. Nothing is straight forward
Head unit cable
adapter cable and button insert
- brooneye
I had a similar problem with mine regarding CarPlay and it turned out the usb cable was in the wrong port on the back of the head unit. Iirc it has to be in port one to activate CarPlay
- JD2k
- Whitey
Hopefully brooneyes solution will work. I found that CarPlay would drop out if using either usb extensions or cheap usb leads from the Headinit. I ended up buying a belkin usb lead which was only a couple of quid more than a cheapy. No problems since
