thanks glen lots more planned but money or lack of is my problem at the min
Liams Mk4
- Liam
Re: My Mk4 reflex silver
Build thread here
Build thread here
Caddy63-Adrian
- Liam
Not much of an update but the german style plates arrived yesterday
gonna try organise a remap with joe power today
Build thread here
Build thread here
- Liam
Remap organised for this friday
but in the mean time i fitted my bike mount that i picked up off amazon for €25 i added an extra piece of timber under the bracket so that it would give me extra support on the floor and more surface area to screw down as i didnt want screwing down through the metal floor of the van so now instead of 2 screws holding it to 12.5mm of ply i have 6 screws holding it to 25mm ply i also carpeted it just to tidy it up
Build thread here
Build thread here
- Afield23
Re: Liams Mk4
I like the bike mount have you got a link to it? Is the 25mm ply fitted to the floor?
- Caddyluv
Re: Liams Mk4
It’s going to get dirty
- Liam
Re: Liams Mk4
it wont get used
Build thread here
Build thread here
- Liam
Re: Liams Mk4
Delta Unisex Hitch Pro Travel Mount for Bike, Black, 600 ml https://www.amazon.co.uk/dp/B000ACAM7E/ ... fBbEVCSVA0
ive a sheet of 12.5 mm ply on floor its not bonded down but its a tight fit it has insulation under it and carpet on top then i added this extra piece of 12.5 mm ply its also carpetted so about 30mm total
Build thread here
Build thread here
- Afield23
Re: Liams Mk4
Ah I see yeah that makes sense. I've just purchased a slightly different one because I have 15mm axle, same brand though so thanks for the link. I'm thinking about mounting it to a thick piece of wood that fits the width of the van so I don't need to fix it to the floor. Should work I think.
- Liam
Re: Liams Mk4
yea i had the same idea so it could be removeable u could also add a second one on same timberAfield23 wrote: ↑Tue Jun 05, 2018 12:40 pm Ah I see yeah that makes sense. I've just purchased a slightly different one because I have 15mm axle, same brand though so thanks for the link. I'm thinking about mounting it to a thick piece of wood that fits the width of the van so I don't need to fix it to the floor. Should work I think.
Build thread here
Build thread here
- Liam
Re: Liams Mk4
Tackled a wireless charger today the wireless charging cradle i had, decided to become all loose and wonky so i dismantled it and used it as the basis for my wireless charge pad
put some tech 7 bond on the charger to hold it in place then fitted a piece of wood to hold it til the bond set
converted a 2amp 12v usb adapter into a wired version and wired it up to a fused supply from the ignition side of the fuse panel under the steering column
earth point taken off the bolt at the gear stick
all done
all doneSent from my iPhone using Tapatalk
Build thread here
Build thread here
- Caddyluv
Re: Liams Mk4
Well done. That’s to scary for me. I could see
in my future.
in my future. Sent from my iPhone using Tapatalk
- Liam
Re: Liams Mk4
its simple enough but a matter of fusing correctly with a low amp fuse and making good connections - this pad has been well tested over past few months so i know its a safe one ive had cheap wireless chargers before that overheated so didnt want that happening here
Build thread here
Build thread here
- Caddyluv
Re: Liams Mk4
Sounds good. It’s not at the top of my list but I think I should do it.
- Liam
Re: Liams Mk4
its just convenient im going to order the rubber phone insert instead of the carpet but it will do for now
Build thread here
Build thread here
