My Caddy 4, 1.4 TSI, Acapulco blue
- Giddy
Re: My Caddy 4, 1.4 TSI, Acapulco blue
Hi Pete, it's an OEM gloss grille. It looks different in the picture, because I took it apart into separate bits, so I can properly wrap the chrome pieces.
The entire gloss black piece can be unclipped from the frame and then you can remove the individual chrome strips. The third top strip is attached directly to the frame, but can also be removed.
Hope this helps.
Hope this helps.
That is great, just the info needed.
Cheers.
Cheers.
- R22LRM
Great work, stunning van this
R22LRM
Mk5 Tfsi powered
Mk5 Tfsi powered
Now I have one ...
You must separate the Gloss cover from the grill base structure in order to remove the chrome pieces.
Top one looks like it will come off, but the big centre alignment clip is covered by the gloss front cover and can't be released !!!
All other chrome clips are hidden in the assembled grill
32 clips on the Gloss cover.
18 clips on the top chrome piece.
9 clips per smaller chrome piece (36).
Total 86 clippy bits to release/pry.
Now just have to try my hand at wrapping !
Etc.
p.s. Any wrapping tips ?
Etc.
Reason: combined two posts in one
- Giddy
Don't know if I can give you any useful tips
Maybe watch some youtube videos and give it a go, see what's working for you. That's what I did
Upon refitting the wrapped bits back you may find that one or two are quite tight and can pull the wrap up. I've used the needle files to file off the high spots on the grille.
Every little helps !
Berger
Vans looking really nice Giddy, can I ask where you got the motexion bulkhead from?
Instagram @berger2k
- Giddy
Hi Berger, good to see you back. I bought it from TPS. They are Motexion distributors now.
Berger
Hi,
Went All Black.
My centre badge is all black.
Yours looks great because it all matches with the tinted badge and tinted bar. Thought it might look odd mixing it on mine, so stuck with just black.
Thanks for inspiration and help.
Pete
Went All Black.
Pete
- Giddy
Yeah, we all have a slightly different vision. It's all about what works for you and what you want to achieve
- Giddy
Fitted and coded the OEM Bi-Xenon headlights and also fitted my gloss black grille. Somehow it makes the van look just a little bit more modern.
Lovely upgrades Giddy, van really is looking stunning.
