My Caddy 4, 1.4 TSI, Acapulco blue
- Caddy Dan123
Re: My Caddy 4, 1.4 TSI, Acapulco blue
@Giddy what lower bumper is that dude is it the alltrack?
Don't suppose you could put links up for the Forge Motorsport induction kit dude been looking for decent intake but find nothing for the 1.4tsi. everyone tells me its same engine as the golf 1.4 tsi but there 185bhp standard so not sure on fitment.
Reason: combined two posts in one, removed quoted pictures
- Ripley55
Gorgeous looking lights @Giddy
Did you go 25w or straight in at 35w
they really set the Van off a treat mate
- Giddy
Thanks lads for you kind comments.
@Ripley55 Yes, straight to 35W upgrade mate
@Caddy Dan123 Yes it's an Alltrack splitter. As for the complete induction kit you need part numbers FMINDK14 and FMDV1, assuming you talking about the EA211 engine.
These are the correct links at the time of posting:
https://www.forgemotorsport.co.uk/12_14 ... -1621.html
https://www.forgemotorsport.co.uk/Dump_ ... -1431.html
- Farky77
Awesome build mate
Just read it from start to finish this morning!
Plenty food for thought for when I eventually find my Caddy
- Caddy Dan123
@Giddy not sure dude mine is 2016 1.4 tsi 7 speed dsg with stage 1 running 180bhp. Keep trying to find an intake but not sure what fits yours suits it keeps it tidy under the bonnet love the build man
- Giddy
@Caddy Dan123
What's your engine code mate? Mine is CZCB, I believe yours should be the same. You can find a sticker on the timing belt cover, also a sticker with all the spec in the fuse box under the steering wheel or in your user manual.
- Caddy Dan123
@Giddy ye man mines same dude
they dont do alot engine wise for the 1.4s do they i love mine though good on fuel and gearbox is smooth pulls well too i was going to get the 2.0tdi but saw that and couldnt resist man.
they dont do alot engine wise for the 1.4s do they i love mine though good on fuel and gearbox is smooth pulls well too i was going to get the 2.0tdi but saw that and couldnt resist man.Sent from my SM-G998B using Tapatalk
Reflexgeorge
Love this van, looks great
Looking really good, giddy!
- Giddy
Thanks lads for your kind comments.
A little teaser of what's coming next. Just received these callipers back from a forum member @ToiletTFSI after a colour change. Now the real challenge is to find some time and fit them before the Tatton Park!
p.s. The decal idea borrowed from Doc's build thread
Wow
They look spiffing
They look spiffing
- BenXCIV
Are the smaller set being used in a dual-caliper set up for the rear, or are they just replacing the factory ones?
- Giddy
Thanks lads. Yes, the smaller set is the rear callipers, but it's a single calliper setup with hydraulic handbrake mechanisms bolted to each bracket, which will apply rear brakes when the handbrake is engaged.
- fazer909
ooft thats quite a set up ! ... thats gonna look the biz
- Giddy
Test fitted the front brakes. Rotor is a bit too close to the ball joint, measured 0.8mm
Will have to order different bells and brackets to push everything outward by about 5mm. Shame the brakes are not going to be fitted for the Tatton Park.
