3.2 v6 Turbo DSG 4X4 Multi link Conversion
Pineapple1984
3.2 v6 DSG Supercharged 4X4 Multi link Conversion
Post by Pineapple1984 »
Mine has a forged crank although I have got another spare? it’s one less thing I need to buy Image Image
NZDubNurd
Re: 3.2 v6 DSG Supercharged 4X4 Multi link Conversion
Post by NZDubNurd »
Pineapple1984 wrote: Sun Apr 06, 2025 7:18 pm @NZDubNurd - ha ha, I have a very long list of chores at home and a very angry wife to go with it. If only she knew how much cash I’ve blown on this she would go mental Image
Glad you’re enjoying the thread though.
I have a question actually regarding coding for ABS module. Did your touran ABS support the haldex or like me did you need to change the module? I’ve got an R32 one to go on but not quite got around to fitting it yet!
Been there... :shock:
I had to swap the ABS unit. Turns out the hydraulic block was the same, just the module part needed swapping, though I did swap the whole thing... then a valve stuck and I swapped back to my original :lol: Mine was just MK60, not EC1. The MK60 block has a 4 digit code engraved in the alloy and if they match, they're the same setup.
I used a unit from a mate wrecking an R32.
Pineapple1984
Okay so I’ve got quite a few bits turning up now
So got the block honed and cleaned ready for the build Image
Wossner Forged compression lowering pistons.
Pineapple1984
Set the ring gaps at 0.19thou top and 0.22thou second so aired on the side of caution by a nats nut.
Pineapple1984
Forged pistons mean forged rods!
Pineapple1984
And that is as far as I got in regards to engine assembly other than putting the crank in with new mains, thrusts and bolts. I forgot the fact the vr6 has a bevelled cylinder so a standard ring compressor is no good, so until the tool turns up that’s it for the minute.
Pineapple1984
I did pick up the turbo and manifolds from stealth as I got some bits from Jon who works there Image
To give a size comparison thats a turbo from 1.6tdi cr Image
Pineapple1984
Pineapple1984
Re: 3.2 v6 Turbo DSG 4X4 Multi link Conversion
Short block built up
Pineapple1984
Rtmg dual mass
Pineapple1984
I didn’t get any proper pics of the upgraded clutch change in the DSG but if anyone needs to change one on a DQ250 you remove the cover for the clutch then the circlip on the basket then the snap ring on the shaft
Pineapple1984
Slide the old clutch pack off!
Pineapple1984
Slide the new one on and put a 2.00mm snap ring in that comes in the shim kit. Measure the end float on the clutch basket only with a dti and write this number down.
Mine was 0.15
Then measure the end float of the primary shaft
Mine was 0.10
Then take the last figure from the 1st figure so 0.5
Then add this to the constant value 1.85
So mine was 1.90 this gives you the correct snap ring size to set the end float
Pineapple1984
Pineapple1984 wrote:Image
Mine was 0.15
Mine was 0.10
Change the cover when you reassemble or from experience they leak
Pineapple1984
Engine built
