Cross Caddy MY 2015
anoneamus
Re: Cross Caddy MY 2015
Post by anoneamus »
Dobbo wrote:the ride height of the cross, would that be the same as a maxi? Just I would like to get the same size tires and give it that off road look.
The ride height of the Cross is exactly the same as the other 2WD models. The AWD Cross and non-Cross are slightly higher at the back to accommodate the rear diff. These tyres add about another 15mm to the height (which at its lowest point on a Caddy is about 150mm).
Dobbo
Post by Dobbo »
anoneamus wrote:The ride height of the Cross is exactly the same as the other 2WD models. The AWD Cross and non-Cross are slightly higher at the back to accommodate the rear diff. These tyres add about another 15mm to the height (which at its lowest point on a Caddy is about 150mm).
Thanks for the reply,
So if I don't have 312mm discs, putting 205/70/15 shouldn't be a problem, oh I'm excited(simple things) :lol:
anoneamus
Post by anoneamus »
Dobbo wrote:Thanks for the reply,
I'm not clued up on disc sizes on Caddys, but if your's can take 15" rims then it can take the (slightly) bigger tyre. I don't know how it will fare if it has been lowered. There is about a 10-15mm clearance on the inside of the rear tyre to the closest point on the rear inner fender (or plastic mudguard, whatever you want to call it).
anoneamus
Post by anoneamus »
Fitted T5 indicator repeaters. No modifications to the car (including wiring) were necessary. Just a bit of Dremeling on the plastic.
Part numbers:
7E0949101D9B9 - Left (black)
7E0949102D9B9 - Right (black)
kully12
Post by kully12 »
Do you have pictures of your headlights and the work you did on them?
Was it a lot of work?
anoneamus
Post by anoneamus »
There are pictures in this thread. I made a "how to" guide:
https://caddy2k.com/forum/viewtopic.php?f=22&t=25064
It's a fair amount of work, by far the hardest part was figuring out the coding, as noone (on here) really knew and I had to figure out a lot of it myself. That info is all in the "how-to" thread now.
There's also this if it helps:
https://caddy2k.com/forum/viewtopic.php?f=6&t=23662
https://caddy2k.com/forum/viewtopic.php?f=6&t=24912
TonyC
Post by TonyC »
Love this :D
Your cape town backdrops are much more scenic than my grey scotland ones
anoneamus
Post by anoneamus »
Thanks! :D
Cape Town is ridiculously beautiful, not a lot of cities in this world that can compete... ;)
TonyC
Post by TonyC »
I was born in Pretoria but my parents left when i was 2 to return to the UK so i remember nothing of it but I'd love to go and visit. It's on my bucket list and i will definitely tick that one off, also fancy some cage diving while i'm there :D
anoneamus
Post by anoneamus »
Had alloys powder coated (were sprayed previously), fitted VW mudflaps.
Roma211
Post by Roma211 »
anoneamus wrote: Tue Feb 13, 2018 11:14 am Fitted T5 indicator repeaters. No modifications to the car (including wiring) were necessary. Just a bit of Dremeling on the plastic.
Part numbers:
hi, and there is a report how did you turn the turn on the wing? What part did you remove sawed with a Dremel?
Roman Agapov, Kazakhstan Almaty
anoneamus
Post by anoneamus »
Roma211 wrote: Thu Nov 29, 2018 5:28 pm how did you turn the turn on the wing? What part did you remove sawed with a Dremel?
This is what I wrote on another thread at the time:
"I didn't want to (and wouldn't) modify the car, when you can just modify the plastic with a Dremel. You need to cut the clip off the one end, and grind that end down a bit so that when you use the "badge tape" it won't protude from the bodywork. I also ground the other end down a bit and replaced the tape that was on there.
As far as the electrics go, you can swap out the original clear bulb with the orange one that comes with the new repeater. Then fold the rubber from the original down as far as it can go, put the old holder into the new repeater as far as it can go and fold the rubber up again around the new repeater "barrel". Works a charm, zero modification to the car. :)"
Roma211
Post by Roma211 »
Can I have a photo please?
anoneamus
Post by anoneamus »
Sorry, don't have. You're a smart guy, I'm sure you can figure it out. I did. ;)
Roma211
Post by Roma211 »
Do you have a repeater on a double-sided tape? no longer fixed? I understood correctly?
