Ravenna Blue Caddy Tfsi
J_Con
Re: Ravenna Blue Caddy
Post by J_Con »
Grille and trim painted gloss black with a Ravenna blue stripe along the front to change it up a little bit.
Mk7 fogs added also with resistors to stop them showing up any faults
J_Con
Post by J_Con »
Door cards stripped for adding door warning lights
J_Con
Post by J_Con »
RNS510 with dab and nav fitted
Heated windscreen panel fitted and working which means auto headlights, coming home lights and auto wipers all work alsoImageImageImageImageImage
J_Con
Post by J_Con »
Couple of photos from a meet at irvineImageImage
J_Con
Post by J_Con »
Aero folding mirrors fitted and regulators changed.
Folding when you hold the lock button nowImageImageImage
J_Con
Post by J_Con »
Touran R Line bumper fitted with a custom stainless steel exhaust Image
Ripley55
Post by Ripley55 »
@J_Con
That's absolutely stunning mate, congratulations on a lovely Van 8)
Cracking picture, van looks amazing.
J_Con
Post by J_Con »
Cheers @Ripley55 I appreciate that
Thanks @FishermansFriend
J_Con
Post by J_Con »
Picked up some Scirocco gauges just need to get the housing for itImage
SupaStar88
Post by SupaStar88 »
J_Con wrote: Thu May 26, 2022 10:42 am Picked up some Scirocco gauges just need to get the housing for itImage
gorgeous can mate, how easy are these to fit?
J_Con
Post by J_Con »
@SupaStar88 thanks! I think fairly straightforward from what I've read it's more fabricating where it goes so it sits properly
SupaStar88
i've got the touran dash to fit so thinking it might have a decent location where the top cupboard unit is, are you doing a guide of fitting?
Reason: removed quote of previous post
J_Con
Post by J_Con »
@SupaStar88 yeah the top storage part works, my caddy one came with the latch so I'll be using that hopefully. I always say I am gonna then I've started something and remember
J_Con
Post by J_Con »
Sunstrip fitted again after having a heated windscreen put in last year ImageImage
