Starlight Blue Caddy Life Mk4 2K SA 1.4TSI DSG - WAV + Stealth Camper for One.
Re: Starlight Blue Caddy Life Mk4 2K SA 1.4TSI DSG - WAV + Stealth Camper for One.
Yesterday ...
Finished off fitting a Voltmeter and a changeover switch to my armrest rear panel.
Switches voltage reading and 12V socket between main and aux. batteries.
V.Short Video
https://youtu.be/EmCnWaGqvCs
Posted in the How To section
Removing rear cover from Caddy Life armrest + Fitting Voltmeter and switch
Popped over to STA Autogearbox, Aylesbury for a TCU remap upgrade from DSG masters TVS Engineering, NL.
Stage 2+ TCU software update.
STA Aylesbury did a good price and I can recommend them.
https://tvsengineering.com/en/ - Select Your Vehicle
https://www.staautogearbox.co.uk/
Very pleasant drive back home
:D
Stage 2+ TCU
Features
- Optimized D Shift Program
- Optimized S Shift Program
- Optimized M Shift Program
- Improved Clutch Control
- Vibration bump reduction
- 1st Gear de- or reactivation (optional)
- Improved clutch cooling
- Improved thermomanagment
- Maximum gearbox torque [Nm] Stock 280 Nm Raised to 350 Nm
- Increased maximum clutch pressure
- Necessary torque limiters raised
- Improved up- and downshifting speed (D+S+M mode)
- Improved shifting paddles response
- Improved take off (D+S+M mode)
- Improved torque reduction during shifting (D+S+M mode)
- Automatic upshift deactivation (optional)
- Automatic downshift deactivation (optional)
- Kick-down deactivation (optional)
- Gear Display Indicator (MFA) activation (optional)
- Reduced engine braking (optional)
- Coasting disabling (optional)
Last few days ... Installing a Blind Spot Monitor System
Hints and Tips Video
https://youtu.be/iTHMyaJZbNQ
Lots of fun !
:D
DW2207
Post by DW2207 »
Very well documented video there Petrev
Sent from my SM-S921B using Tapatalk
Thanks.
Bare bones, but hopefully useful.
I put a link in the description to a full install video by a clever car tech guy in NZ
mixa96
Re: Starlight Blue Caddy Life - Mk4 2K SA - WAV + Stealth Camper for One.
Post by mixa96 »
Great job :D
Did you replace the black and white display with color here or did you have to change cluster?
Reason: Removed multiple photo quote
Caddy Maxi 2.0 TDI 150HP DSG DQ250
Engine Stage 1 190HP DSG Stage 3
I changed the cluster to a Scirocco R colour 3D premium.
It's the biz
:D
