.Let the build begin - Plushed/Bagged VR6
Gary.8
Re: Let the build begin continues with VR6 heart transplant
Kudos Colin and that engine bay looks awesome
.- C Chis
Cheers guys!
- C Chis
A little trip to get the alignment checked and adjusted.
Turned out that the Toe was initially out by over 4 degrees and the Caster was also way out, not surprising really as I fitted an electromechanical steering rack in place of the hydraulic one and had the subframe off.
Van was quite skittish on the way to get it aligned and awesome on the way back!
Also good to know that the subframe, suspension and steering is all in tip top condition.
- C Chis
[mention]Papa Bear [/mention] might be down your way(ish) this summer, heading to South Wales to visit family and Bike Park Wales.
- Alex mc
@C Chis A visit to pro grip mate . Johns the man when it come to alignment I wouldn’t go anywhere else .
- C Chis
[mention]Alex mc [/mention] yeah, came highly recommended!
Good guy right enough.
Spent an hour going over things and making adjustments!
Vans handling brilliantly now!
Well Liverpool is on the way to Hampshire if you’re coming from Scotland. We’ve got the Mersey tunnel
- C Chis
Haha, I might just do that too!
Jeez ! But that looks mighty fine !!!
Sounds good too no doubt.
Is there still a battery under that rather fine air filter ?
- C Chis
[mention]petrev [/mention] cheers buddy!
It certainly does sound mighty fine! Still grinning from ear to ear every time I fire it up and drive it!
Battery has been relocated to behind the passenger seat, still to sort out a battery jumper connection just in case required.
I still need to remove some redundant wiring and wrap the loom, weekend job I think.
Love it
Jump start wise, there is the nice fat +ve input wire to the fuse box just there in the engine bay.
- C Chis
So, replacement engine not always starting on the first crank or taking a while to start, time to investigate!
Options…
1. No/low fuel pressure
2. Something faulty in the intake
3. Injector fault
4. Tired battery
So, first option 4
Fired up first time, brilliant, turns out the Quattro’s battery is 10+ years old and needs replaced.
Time to remove the old TDI rear badge and replace with something a little more in keeping…
And might as well label the engine and grill up too!
Options…
3. Injector fault
4. Tired battery
So, first option 4
- C Chis
Replacement heater panel fitted today along with heated seats and aircon regas after the engine install.
Saves a dash out and climatic to climatronic swap for heated seats, result!
Now I’ll have to do something about the nail marks!
- C Chis
Cleared the last error code today… G85 no communication.
After a lot of checking and rechecking, swapping out steering angle senders and steering wheel control modules finally found the problem…
Turns out the the steering wheel control module in a van with hydraulic power steering only has 1 pair of canbus wires (convenience can) although the wiring diagrams show 2 pairs, convenience and drive canbus there was wasn’t 2 pairs.
Steering module with only 1 pair of canbus wires
It was only through the power of this forum that I found the answer! There was an old post from several years back that the OP posted up about the exact same issue and the solution he found, brilliant!
Drive canbus wires added in. Salvaged from the donor Audi wiring harness.
Error free instrument cluster! Even a 20 minute traffic delay couldn’t wipe the big grin off my face on the way home after adapting the steering assist!
Don’t you just love the power of a good forum! Ta!
Nice one, glad you're now error free.
Time for some proper road miles now.
